This is a placeholder topic for “10kg Beam Load Cell” comments.
A 10kg bar load cell, perfect for weighing heavier objects!
Read moreThis is a placeholder topic for “10kg Beam Load Cell” comments.
Read moreWhat are the physical dimensions of the bar?
Welcome back Anthony ![]()
At the moment we arent 100% certain what the dimensions for the load cell will be.
I imagine it will be the same as the 3 kg load cell
- Dimensions: 12.7 mm x 12.7 mm x 75mm
- Mounting points: 10 mm between holes suited for M4 bolts (5.5mm from edge)
I’ve added a note to confirm dimensions as soon as a shipment arrives!
If you do choose to go with this load cell and have a project that requires certain dimensions and they dont match the specs above we’ll get in touch via email
PS: We have this load cell listed with set dimensions if you need it ASAP: Strain Gauge Load Cell - 4 Wires - 10Kg | Adafruit ADA4542 | Core Electronics Australia
Are these compatible with HX711 amplifier?
