I have to mearsure a load of around 20kg with a resolution of around 50grams.
I have been looking on the following load cell and amplifier:
Load cells:
Amplifier:
How do i calculate the resolution?
By resoultuion i mean every change in force aplied.
Can i for instance measure a difference between: 10.00kg and 10.05kg or 0.30kg and 0.35kg?
From a quick search through the HX711 datasheet the resolutions is somewhere in the 24-bit range - note that to get the highest accuracy reading your load cell should be rated for 2x the mass that it carries.
From my understanding load cells have a close to linear relation across its ‘accurate range’ - the calibration that you do and the environment factor in a lot to how it runs.
With the 20kg load cell I think you’ll be fine to measure 10.00kg vs 10.05kg but you’ll have to do more calibration to get it working lower down accurately.
