This is a placeholder topic for “12V Miniature Diaphragm Pump” comments.
This is a 12V Miniature Diaphragm Pump of great power with a wide range of applications. Drove by an electric motor, the maximum work pressure of the pump is up … read more
Am looking for a pump/Compressor (twin head) to transfer atmospheric air at flow rate of 60 LPM at 2 barg pressure or at the flow rate of 30 LPM at 2 barg. Any help in this regards would be highly appreciated.
Mahe
Hi Mahe,
As far as air pumps go, the only applicable option we have is this vacuum pump, and according to the spec sheet, it can only achieve 12-15LPM with free flow.
Having a cursory look, it seems you might have to go to an industrial supplier with your requirements as a next step, or find a high volume air compressor that would be compatible with your project.
Maybe try supercheap or bunnings for a small 12v compressor. There are some pretty cute ones intended for emergency use.
