Hi guys!!
Just looking at the • Air Pump and Vacuum DC
Motor
- 4.5V and 1.8 LPM
ZR320-02PM
I was wondering if there was a battery power supply and a switch you could recommend if possible to just have it ran as easy as that.
It’s to blow smoke out of a model volcano so didn’t want to have to go to fancy if I didn’t have to running with the keep it simple theory.
I just wanted to kind of grab everything at once from you guys if possible.
Thanks in advance
Hi Jacob,
Just looking through the description of that air / vacuum pump I noticed it’s not designed for continuous operation. It’s typically used to turn on and run flat out for a while, then shutdown to cool off. Since you don’t need to pumping with high pressure to blow smoke out of your model volcano you might be better off with a simple fan instead.
I think if you get a fan like this:
And a battery holder with a switch:
And connect it using some pigtail alligator clips:
Then you should be able to just use the switch on the battery holder to turn the fan on and off, and you’ll have a quieter (but not totally silent) fan. The air/vacuum pump is more suited to something like inflating a balloon.
