3mm Hexagonal Shaft Adapter for LEGO® Wheels (Pair) (POLOLU-1011)
This is a placeholder topic for “3mm Hexagonal Shaft Adapter for LEGO® Wheels (Pair)” comments.
This adapter allows 3mm hexagonal shafts, the kind found on many Tamiya gearboxes, to be connected to LEGO’s wide variety of high-quality wheels. The adapters are sold in pairs.
Can you tell me the the outer dimension of the shaft adapter SKU-Pololu-1011.
Also, will the splines + fit to a Lego Actuator?
Many thanks
John.
Hey John, Welcome to the forum!
The cross-shaped shaft end should definitely fit into an actuator, if this part is what you’re talking about:
https://www.brickowl.com/catalog/lego-linear-actuator-10-15-61927
I’ve measured the cylindrical section, and it’s about 6.6mm if that helps.
Let me know if you need any more measurements!
Many thanks for the measurements James. Just what I needed to know.
I will get back on your site and make an order.
Thanks again.
John.
