I have a question regarding which motors to use with the Pololu Wheel 60x8mm wheels? (Pololu Wheel 60x8mm Pair - Black Australia)
Thanks in advance.
Thanks in advance.
Hi Moritz,
That will depend more on what you are trying to move, Pololu makes some good hub adapters found here: M3 Holes Hub Australia (this is for the M3 holes which I find easier to find and use). You might have to drill out some parts of the plastic to get bigger shafts in.
In short go for something with a shaft between 3 and 8mm to work with those hubs (something like this stepper: Stepper Motor with Cable Australia).
Let me know if there is anything else I can help with!
