Hi There,
I came up with this. It works no problem.
I post it here for the next guy. I will also post it on the product forum.
You call it like this.
displayNumber = '123.4'
displayTimer = 5 # Display time in seconds (Approximate)
displayLED(displayNumber,displayTimer)
It right justifies the number with a blank if less than 4 digits.
It displays and ‘E’ for error if something goes wrong.
I’m sure there are probably better ways to do this but it works
I hope this helps someone else.
David
from machine import Pin,SPI,PWM
import framebuf
import time
MOSI = 11
SCK = 10
RCLK = 9
THOUSANDS = 0xFE
HUNDREDS = 0xFD
TENS = 0xFB
UNITS = 0xF7
Dot = 0x80
SEG8Code = [
0x3F, # 0
0x06, # 1
0x5B, # 2
0x4F, # 3
0x66, # 4
0x6D, # 5
0x7D, # 6
0x07, # 7
0x7F, # 8
0x6F, # 9
0x77, # A (10)
0x7C, # b (11)
0x39, # C (12)
0x5E, # d (13)
0x79, # E (14)
0x71, # F (15)
0x00, # Blank (16)
0x00 # Decimal Point (17)
class LED_8SEG():
def __init__(self):
self.rclk = Pin(RCLK,Pin.OUT)
self.rclk(1)
self.spi = SPI(1)
self.spi = SPI(1,1000_000)
self.spi = SPI(1,10000_000,polarity=0, phase=0,sck=Pin(SCK),mosi=Pin(MOSI),miso=None)
self.SEG8=SEG8Code
function: Send Command
parameter:
Num: bit select
Seg:segment select
Info:The data transfer
def write_cmd(self, Num, Seg):
self.rclk(1)
self.spi.write(bytearray([Num]))
self.spi.write(bytearray([Seg]))
self.rclk(0)
time.sleep(0.002)
self.rclk(1)
def decodeString(displayString):
displayList=[]
for character in displayString:
if character == '0': code=0
if character == '1': code=1
if character == '2': code=2
if character == '3': code=3
if character == '4': code=4
if character == '5': code=5
if character == '6': code=6
if character == '7': code=7
if character == '8': code=8
if character == '9': code=9
if character == 'A' or character == 'a' : code=10
if character == 'B' or character == 'b' : code=11
if character == 'C' or character == 'c' : code=12
if character == 'D' or character == 'd' : code=13
if character == 'E' or character == 'e' : code=14
if character == 'F' or character == 'f' : code=15
if character == ' ': code=16
if character == '.': code=17
if code != 17: displayList.append(code)
return displayList
def decimalPlace(displayString):
currentPosition=4
break
currentPosition=currentPosition -1
return currentPosition
def displayLED(displayNumber,displayTimer):
try:
outputDisplay(displayNumber,displayTimer)
except:
print("Error")
LED=LED_8SEG()
LED.write_cmd(THOUSANDS,LED.SEG8[14]) # Display E
time.sleep(0.0005)
def outputDisplay(displayNumber,displayTimer):
displayTimer = displayTimer* 110 # Convert timer to seconds
displayString=str(displayNumber)
# Left Pad with blanks
noDecimal=displayString.replace('.','') # Remove decimal point
stringLength=len(noDecimal)
if stringLength==3: displayString=' ' + displayString
if stringLength==2: displayString=' ' + displayString
if stringLength==1: displayString=' ' + displayString
print("displayString="+displayString)
displayList= decodeString(displayString)
decimalPosition=decimalPlace(displayString)
LED=LED_8SEG()
while displayTimer > 0:
time.sleep(0.0005)
if decimalPosition == 0:
LED.write_cmd(UNITS,LED.SEG8[displayList[3]]|Dot)
else:
LED.write_cmd(UNITS,LED.SEG8[displayList[3]])
time.sleep(0.0005)
if decimalPosition == 1:
LED.write_cmd(TENS,LED.SEG8[displayList[2]]|Dot)
else:
LED.write_cmd(TENS,LED.SEG8[displayList[2]])
time.sleep(0.0005)
if decimalPosition == 2:
LED.write_cmd(HUNDREDS,LED.SEG8[displayList[1]]|Dot)
else:
LED.write_cmd(HUNDREDS,LED.SEG8[displayList[1]])
time.sleep(0.0005)
if decimalPosition == 3:
LED.write_cmd(THOUSANDS,LED.SEG8[displayList[0]]|Dot)
else:
LED.write_cmd(THOUSANDS,LED.SEG8[displayList[0]])
time.sleep(0.0005)
displayTimer = displayTimer-1
# Once finished blank out the fist left most digit
# as it's the only one that sticks
LED.write_cmd(UNITS,LED.SEG8[16])
time.sleep(0.0005)
# TEST
displayTimer = 5 # Display time in seconds (Aproximate)
