4-pin JST PH to JST SH Cable - STEMMA to QT / Qwiic - 200mm long (ADA4424)
This is a placeholder topic for “4-pin JST PH to JST SH Cable - STEMMA to QT / Qwiic - 200mm long” comments.
Are you a maker in the midst of a STEMMA dilemma? This 200mm long 4-wire cable is a fantastic chimera-cable fitted with STEMMA QT / Sparkfun Qwiic JST SH on one…
Hi, is there a version of SKU ADA4424 longer than 200mm? Thanks.
Hey @Chris177918,
Welcome to the forum!
The 200 mm cable is the longest we currently stock. However, you can easily extend it by cutting the cable and adding sections of your desired length using 28 AWG wire and heat shrinks.
