This is a placeholder topic for “JST-PH 2-pin Jumper Cable - 100mm long” comments.
This hand little 2 pin JST PH connector is perfect for all Adafruit’s battery packs!
Read moreThis is a placeholder topic for “JST-PH 2-pin Jumper Cable - 100mm long” comments.
Read moreAre there longer versions of this jumper cable available?
How long did you need? There’s a slightly longer one (150mm, SKU: PRT-09914, that’s a single side of the cable)
The other option would be to grab the connectors and make a cable yourself.
Hi Mark,
You could also join them to this: JST-PH Battery Extension Cable - 500mm | Buy in Australia | ADA1131 | Adafruit | Core Electronics to make a longer one
