5.8dBi Fiberglass Antenna - N-Type to RP-SMA - White - 902MHz-928MHz (RW-915004)
This is a placeholder topic for “5.8dBi Fiberglass Antenna - N-Type to RP-SMA - White - 902MHz-928MHz” comments.
Omnidirectional 902-928 MHz dipole antenna provides 5.8 dBi gain and 360° coverage for LoRaWAN with weatherproof fibreglass housing and N-type connector.
is there a pigtail available to connect this antenna directly to a u.FL / MFH1 (on the RAK19003 Base Board)? thanks
Hey there, @James159602,
An N-Type to UFL pigtail is unfortunately not something we have in a range right now. If you need to connect it to the included cable, you would be able to with the 65 mm I-PEX MHF1-to-RP-SMA pigtail.That should connect the supplied cable to your module’s u.FL socket, rather than replacing the supplied cable entirely.
Otherwise, we might be able to procure a pigtail from our suppliers, but that would be best to discuss that by reaching out to our Customer Service team at support@coreelectronics.com.au, as we may need some additional information from you.
