LoRa Fiberglass Antenna Kit; 902-928MHz-3dBi with Antenna Base (SS318020652)
This is a placeholder topic for “LoRa Fiberglass Antenna Kit; 902-928MHz-3dBi with Antenna Base” comments.
LoRa-Fiberglass Antenna-902-928MHz-3 dBi-360mm-Seeed Studios…
Can the base be screwed down onto something?
Hey there, @Daniel333789,
I can’t confirm how the base can be mounted except to confirm hat it is fact not magnetic (the Seeed Studio product page are very clear on that). I don’t have one in the warehouse to confirm its mounting arrangement at this time, however, I will reach out to the supplier to get that bit of information. I’ll let you know when I hear back.
I have two here but not pulled the cover off the base (glued in)
I suspect the base it a steel ring (for weight), with no center to allow for the N connector and cable to find in.
The cable is feed from the top.
As such, I suspect you could drill some holes to place some mounting bolts, or make a bracket of some sort to go over the base.
The other options are to get the antenna without the base and use a pole mount kit.
I think core have a simular, but higher gain antenna for pole mounting.
I pulled off the bottom cover (as you can see).
This shows the inside.
edit:
without checking brands and dimensions etc.
This is the other antenna i was talking about
To me, based only on the photos, the base “silver bit” of the antenna seems the same.
Hi Michael
It would be interesting to find out what is inside the fibreglass tube. I make that metal bit at the bottom 90mm including connector, arrived at by measuring the on screen image and scaling. that leaves 270mm space for the actual antenna. A bit of space is needed between the actual antenna and the metal bit so the available length is somewhat shorter than 270..
There is no provision to connect or install a counterpoise or ground plane so I don’t think a vertical whip type of antenna is used. Could be quite wrong here.
I think maybe the antenna types below could be used.
Now the half wavelength at 915MHz is 156mm allowing for 5% end effect so about what you could accommodate physically would be one half wave dipole. Either a dipole and balun or what used to be known as a “Coaxial Dipole” . Neither of which requires a counterpoise or ground plane. This Coaxial Dipole was used extensively on Marine installations where ground plane rods as normally used are too cumbersome and easily prone to damage.
Your other antenna being much longer would have enough length for half wave dipoles connected as a Co-linear Array. Probably only 2 as I think 4 would be more gain than 5.8dbi
Of course I could be completely wrong here as the gains quoted don’t quite add up.
The shorter antenna if it has only 1 half wave dipole should theoretically be 2.15dbi while the longer one if it has 2 half wave dipoles should be 5.15dbi, a difference of 3db. The manufacturers might have been able to squeeze that little bit more to get 3dbi and 5.8dbi but like I said it would be interesting to discover just what is inside that fibreglass tube.
Yeah, it looks fairly well sealed at a quick look, so not too keen to destroy that for a peek (just yet).
Im never too sure how much I trust the quoted gain… as you would need the “i” (isotropic) reference; then work out a way to test relative to each other and see if the 3dbi give twice the power level at the same distance at a receiver.
But I digress,
With a quick continuity test, the coax shild is connected to the silver N-Contector (outside) as expected which IS connected to the silver base.(which i found interesting) as that would mean IF you did pole mount onto the bit, you would be connecting that to the “ground” of the coax.
I would have expect that to be a dipole (as you said) thus NOT connected to a ground plane… mmmm
Hi Michael
Does not matter.The RF ground plane I refer to is the sheet or radials which connect to the coax shield right at the base of a whip type connector and consist of arms radiating out or a sheet of metal like a car roof or a metal disc. All this should be a bit greater than one quarter wavelength minimum. If the coax is terminated correctly it should not radiate anything so maximum power is radiated fro the bits that should radiate. In other words we keep the RF power where it belongs and where it does the most good.
It is a bit hard to go into at this level as it all is a bit of a black art. Basically for a whip type antenna (usually 1 quarter wavelength) to operate properly needs a ground plane or counterpoise. A PC board with some electronics and some sort of antenna or a bit of wire is NOT a “proper” ground plane and could really do anything.
A balanced dipole mounted horizontally does benefit from an earth mat of some description as then the propagation can be predicted to some extent. The reflections from the ground are used to control the angle of propagation by adjusting the height above the ground mat. Example one half wavelength above the ground results in a 30º upward angle of propagation. This is useful for HF operation. We are talking UHF here in which everything is scaled down.
I guess what I am saying if you are interested you would do better with on line research. Particularly the coaxial dipole. There is an advertisement here for a “coaxial dipole” with s description of the beast.
This one looks remarkably similar to the sort one discussed here. Even the length which is 35cm.
A co-linear array is also an interesting one and is extensively used at high frequencies.
Here is a diagram from a Wikipedia entry of a typical construction.
I agree its ok in that type of antenna design. But in a dipole you should not connect the ground as such. the output of the coax is used for the other half of the dipole, so connecting that to ground would unbalance and affect the antenna perforamce.
So if that outer coax is connected to the mounting hardware, then I suspect it wont be a dipole antenna.
Hi Michael
I don’t think you quite get it. That part of the coax you are referring to at the input connector is NOT part of the antenna. From the centre feed point the coax brain is folded back OVER the outer PVC cable sheath to form the other half of a centre fed dipole. In a commercially made antenna this outer component would probably be a solid tube but for a quick and cheerful antenna you would strip the outer sheath back and fold the braid bak over this to the dimensions shown on that sketch.
When you get to one quarter wavelength don’t forget to reduce the physical length from calculated length by 5% for “end effect”.
For an end fed whip type of antenna you DO need a ground plane for proper operation. The lack of any provision for this here is what makes me thing there is a “coax dipole” inside that fibreglass.
Practical case: A VHF (or UHF etc) antenna at the top of a tower of some sort. Coax cable installed up said tower structure to feed this antenna.
I can assure you that this cable sheath will be stripped and connected to the tower solidly at the top of the run and where the cable exits the tower to connect to TX/RX equipment. And where this cable enters any building. If you want to be really complete this will happen wherever the cable changes direction but this extreme will usually only happen in high lightning areas. You have probably guessed by now this is to minimise lightning damage and the grounding where the cable bends is because lightning does not usually go around corners and will leap across to the nearest grounded piece of metal and take a chunk of cable with it.
I have actually seen this type of damage so it can and does happen.
In a dipole the coax brad/shield is connected the the other half of a dipole
not a ground plain/radials as in a basic antenna.
Hi Michael
Yes you can do that but ideally there would be a Balun (balanced to unbalanced) device at the feed point ie; the centre of the dipole.
Also the behaviour (vertical radiation pattern) will become more predictable if there is a ground mat or very conductive ground underneath.
I feel we are drifting of topic, but i do find it a good dicussion.
I think we are simply talking about different antenna types.
From you picture with the ground plan (coax shield feed back) etc, which I have built a few of, is a monopole (or quarter-wave monopole), where a dipole is as per my image.
monopoles tend to pull the donut down to ground level, thus “flatter” at ground level.
dipoles tend to be ground independent and have the fuller donut shape radiation pattern.
You can mount the dipole vertically as well to give similar, but not the same radiation pattern.
Then there is the “Coaxial Collinear Antenna/phased dipole array” with the lengths of coax alternant inner/outer every 1/4 wave (in the correct multiples)
This again does not need the ground plan connections.
I have built and used all 3 in 1080 Mhz aircraft beacon tracking.
each had their pros/cons
Hi Michael.
Yes we are getting off topic but only a bit. It is an interesting subject though.
A quarter wave whip or monopole as you call it with a ground plane is about the simplest. According to all the info I have seen it actually half a dipole. The bottom half is imaginary and is considered to be below the ground plane or actual ground in the case of larger structures..
The actual impedance of a dipole is 73Ω I think so a monopole is half of that or 36.5Ω. It is made to look like 50Ω by slight adjustment of length or sometimes a matching network.
Most TV transmitting antennas would have you scratching your head unless you actually know. These are mostly many arrays of 4 half wave radiating elements each array fed by a central Balun in front of a reflector screen which is 1/4 wavelength behind them.
Now each radiating element is supported by a steel tube welded to the element and securely bolted to the reflector screen which in turn is bolted to the tower structure.
Got all that. Everything including the radiating elements is securely bolted together and attached to the grounded tower structure.
Now the tricky bit. As far as the RF signal is concerned these radiating elements are sitting in free space and the connection to ground does not exist. How is this done??? Have a think about it and if you can’t work it out and are a good boy I might tell you.
My quick initial thought would be they are in phase with each other (spacing) such that any wave that does go via the metal frame would be in phase which would help with the gain.
My big 433mhz beam for UHF is not connect to any ground or mounting eclectically and works perfect.
