This is a placeholder topic for “5V 1.8A Isolated Output PoE Module Works with Raspberry Pi 3 B+” comments.
Power over Ethernet (PoE) can make your project wiring a breeze - instead of needing a wire for power and data, you can use one Ethernet cable for both! All you … read more
does the raspberry pi 4 support this product
Hi Robert,
Not officially, as the 1.8A current rating of this supply doesn’t meet the 3A recommended for the Pi 4,
You’d likely have success with it, but only if you kept your peripherals to a minimum (no heavy current drawing devices plugged in via USB or GPIO.
What’s your project look like so far?
