600-6000MHz 5G Antenna (TEL0143)
This is a placeholder topic for “600-6000MHz 5G Antenna” comments.
These 5G antennas are designed for 5G modules and equipment that require high efficiency and peak gain to deliver excellent throughput for access points, terminals…
Can you please verify the dimensions of this antenna: TEL0143
The diagram and item description are in conflict with each other.
Hi @Zach229596 , Welcome to the forums!
Unfortunately, we don’t have any of these currently in stock to verify, but I will have our team get back to you with the correct dimensions once we get our hands on this antenna!
Hi @Zach229596 ,
I have measured the new shelf stock we received and can confirm that the measurements in this diagram are accurate.
Hope this helps!
