Hey guys, looking to replace a damaged antenna from a 01dB orion vibration monitor. Without the antenna there is no connection to a cellular network which allows us to connect the monitor to a web interface remotely. Any help on how to replace it wold be appreciated, cheers.
Hi Isaac,
01dB says it’s a 3G antenna, so I’d say something like this will do the trick, and might even give you a better signal!
I’d check the polarity of the antenna you have to make sure it matches the above. Here’s a graphic:
Let me know if you have any more questions!
