This is a placeholder topic for “7.3inch ACeP 7-Color E-Paper E-Ink Display Module, 800×480 Pixels, SPI Communication” comments.
7.3inch ACeP 7-Color E-Paper E-Ink Display Module, 800×480 Pixels, SPI Communication…
Read moreThis is a placeholder topic for “7.3inch ACeP 7-Color E-Paper E-Ink Display Module, 800×480 Pixels, SPI Communication” comments.
Read moreHi there, I don’t know much about the SPI vs HAT e-ink displays. Will the SPI connect to a Raspberry Pi 3B without additional cables? Thanks
Hey Ciaran,
Welcome to the forums!
With this display, you will need to use the driver board. You are unable to just plug the ribbon cable directly into the Pi as it doesn’t work on the same communication protocol.
Blayden
Thanks for that info Blayden. I will have to do a bit more research! I was after a 7" display which would just plug in.
