This is a placeholder topic for "9g micro servo (1.6kg) " comments.
This is the most mini servo. Only weights 9 gram and gives you a 1.6kg.cm torque. Pretty strong regarding its size. Suitable for Beam type robot.
Read moreThis is a placeholder topic for "9g micro servo (1.6kg) " comments.
Read moreHello, I am looking at an SG90 micro servo (9g micro servo (1.6kg) | DFRobot SER0006 | Core Electronics Australia) but was wondering what degrees of rotation this servo had? I am looking for 180. Thanks,
Sam
Hi Sam,
I’ve tested one of these on the bench and found that it can reach about 175 degrees of movement, but this varies unit-to-unit, and type-to-type. Is 175 good enough or should we take a look for something with more range for you?
Hey James, I was looking for 180 so that’s perfect thank you. I’ll pop my order through now. Sam
