Adafruit LC709203F LiPoly / LiIon Fuel Gauge and Battery Monitor - STEMMA JST PH & QT / Qwiic (ADA4712)
This is a placeholder topic for “Adafruit LC709203F LiPoly / LiIon Fuel Gauge and Battery Monitor - STEMMA JST PH & QT / Qwiic” comments.
Low cost Lithium Polymer batteries have revolutionized electronics - they’re thin, they’re light, they can be regulated down to 3.3V and they’re easy to charge. On your phone, there’s a little image of a battery cell that tells you the percentage of charge - so you know when you absolutely need to plug it in and when you can stay untethered
Wondering what is the difference between this, and “Adafruit MAX17048 LiPoly / LiIon Fuel Gauge and Battery Monitor - STEMMA JST PH & QT / Qwiic” ( SKU: ADA5580) ?
I assume they use different ICs, but both appear to do the same thing, and it looks as though the description was a copy and paste job. I have just come across a blog post which suggests MAX17048 is much more accurate than INA219.
As a customer I really want to know which is better (depending of course on my different purpose).
I recently bought a “DFRobot Digital Wattmeter” (SKU: SEN0291), and just now found that DFRobot sell a MAX17048-based “Gravity: I2C 3.7V Li Battery Fuel Gauge” (SKU: DFR0563) … and of course checking which of the other brands you sell have essentially identical products (and the difference in prices).
Hi Donald,
For most makers there might not be too big of a difference, getting the SoC is a huge level up for a lot of projects.
From what I interpreted from the datasheets:
Accuracy
  • MAX17048 offers higher accuracy and features proprietary ModelGauge™ technology for better state-of-charge (SOC) estimation.
  • LC709203F provides efficient monitoring with a simpler algorithm but might not match the precision of MAX17048 for dynamic loads.
Available outputs
  • MAX17048 focuses on SOC estimation, voltage, and current.
  • LC709203F primarily measures SOC and voltage but excludes current sensing.
I guess now its a choice of price vs features, do you need the increased accuracy or current sense capability?
LiPo cells ought to have a much more accurate SoC reading from just the voltage, over a flatter voltage curve chemistry like LiFePO4.
Keen to hear your thoughts!
Probably the wrong thing to say to me :wink:
I come from a software background so am trying to pick things up as I go. The various types of battery are a learning curve (mountain) still in my future :slight_smile:
I agree that having any battery monitoring is a huge level up - but why stop there ? We know that Lithium batteries and solar panels put out variable amounts of power - that’s why we need specialised boards to manage them. Why is it not reasonable that we want to track the power levels ?
Given the MAX17048’s apparent higher accuracy and more detailed info, and the low cost of this Adafruit version, there is no choice :wink: I suppose really its a case of “voltage = 3.27v” wouldn’t have the same urgency as “battery 12%” ! In my case the bigger consideration (which I keep on forgetting) is whether the device is supported by my software ecosystem (I have gone the RasPi and ESPHome route, whereas most of the support is for Arduino :frowning:) and physical connections.
It is a pity that Core’s website’s “Related Products” tab shows unrelated products which supposedly other customers looked at or bought - instead of the similar products from the other suppliers which you sell.
I can understand skipping battery monitoring in low cost products; or in a UPS intended to cover a max 30 minute mains power outage. But even in a UPS, don’t you want to know how much the battery performance has degraded over time, and when it’s time to replace the battery ?
I can’t imagine why DFRobot provides no monitoring capability whatsoever in their top shelf Sunflower: Solar Power Manager boards (which they describe as “for IoT or off-grid projects”). I would expect that from budget products, or an electrical supply company … but from a business built around intelligent controllers, and with real-world applications in mind ?
DFRobot are certainly not alone in this - but it was the diagram for their Solar Power Manager on their I2C Digital Wattmeter (SEN0291) page which suggested for me the importance of monitoring battery and solar inputs by adding 4 Wattmeters effectively doubling the cost. Personally I think monitoring the solar panel and battery inputs are particularly useful, and of course building them into the main board should reduce cost further. It seems odd that even with this top shelf unit we are expected to add battery monitors and presumably buck/boost on the outputs before connecting to our microcontroller.
Have a great day !
Cheers, Don
Hi @Donald23173,
What a deep dive we have here.
It’s kind of for the reason you listed above, lots of hobbyists will skip the monitoring or spec their projects appropriately to ignore it, when there are these external solutions available they can be added down the line.
In all my projects I have battery monitoring in one way or another. Usually, I just care about the charge and don’t care so much about everything else. A voltage divider works here.
Glad to have you here Donald!
Trust me, batteries go very very deep - like most topics.
A quick electronics definition: Power = voltage x current
Whereas with a battery the main variable we want to track as makers is charge (how much juice we have left), charge = remaining chemical potential inside the battery, usually related to the voltage across the terminals for LiPos.
The two options you originally were asking about monitor charge, not so much power.
Looking through the ESPHome integrations there is one for this: Analog Devices MAX17043 battery fuel gauge - ESPHome - Smart Home Made Simple
Gravity: I2C 3.7V Li Battery Fuel Gauge | Buy in Australia | DFR0563 | DFRobot | Core Electronics
Strongly agree, having the percentage there is invaluable, thankfully, with LiPo’s its pretty easy to map the voltage to a SoC (state of charge) in percent, depending on how far down the curve will depend on how you map the voltage.
(However note that this is the open circuit voltage)
I imagine this is an artifact of how the backend works, for much more considered groupings, take a look at the categories: Battery Monitoring - Power & Batteries Australia
The cell health is a bit more difficult to decode from the device its powering, and a lot of things affect how fast a cell ages - there are some great resources around the net and I simply wont do the topic justice.
To be honest, me either! It makes sense that they make another version with those monitors added, but I guess they do also produce them sooo…
In that example they are measuring the consumption of absolutely everything, so pretty overkill but at least one for the battery would have been a great addition.
Hi Folks.
Is there a MicroPython library available for this, or a similar product suitable to Pico?
Cheers.
Thats my point exactly. Being able to monitor battery level is not an esoteric requirement. It seems obvious to everyone except the developers of these products. How hard would it have been to add a voltage divider (two resistors and a header pin) ?
I do accept that adding an INA3221 with i2c interface would add a few dollars and may require a bigger board, but that could be a separate product - and that there may not be as big a market for this.
I did try a MAX17048 and a couple of DFR0563s, but found they were unwieldy, and the ESPHome integration had only the basic MAX17043 functionality. I also found the battery percentage was wildly inaccurate during my testing and realised my automation will rely on voltages anyway. I replaced them with a INA3221 which is monitoring the battery, solar panel and (just because it’s there) the USB input. I am thinking I might leave a USB powerbank attached to the USB-In and have the automation switch it on when the main battery gets down to 3.3v. Hopefully that will give me a few hours to get it sorted. FYI this is my power module … which has given me more trouble than the entire rest of the project.
The “Learn” section of the Adafruit website has an article on using the Adafruit LC709203F, which includes CircuitPython examples and code, and a link to their library for it on github.
Have you tried this and found that there is sufficient difference between CircuitPython and microPython ? I note they also have an article CircuitPython Libraries on MicroPython using the Raspberry Pi Pico
Thanks. I’ll check it out.
So I’ve got the LC709203F talking to the Pico using the LC709203F_CR.py library and the code below.
IC2 comms are hardwired. I’d like to use the STEMMA connector instead of hardwired but I’ve no clue how to mod the code to do this.
Enlightenment appreciated as always.
import time
from machine import I2C, Pin
from LC709203F_CR import LC709203F
print("Make sure LiPoly battery is plugged into the board!")
i2c = I2C(0,scl=Pin(1), sda=Pin(0)) # Sets the pins for comms.  GP0=SDA GP1=SCL
print(i2c.scan()) # Scans for and prints all I2C address.
sensor = LC709203F(i2c) # Assigns the battery module to the variable sensor.
print("IC version:", hex(sensor.ic_version))
while True:
    volt = sensor.cell_voltage
    perc = sensor.cell_percent
    print("Battery: " + str(volt) + " Volts / " + str(perc) + " % Cell")
    time.sleep(300) # seconds
Hi @Mark285907
You’ve got a few options, STEMMA QT, qwiic and Piicodev are for the most part cross compatible, you could look at using something like PiicoDev Expansion Board for Pico (Non-Recharging) | Buy in Australia | CE08677 | Core Electronics the only change you would need to make to your code would be to the line where you tell the Pico what pins to use for i2c communications, you would need to change it out to be the code below.
i2c = I2C(0, scl=Pin(9), sda=Pin(8)) # Sets the pins for comms.  GP8=SDA GP9=SCL
Thanks so much Dan. That works!
…and now I realise my stupidity in forgetting I have the Pico mounted on a PiicoDev LiPo Expansion Board, the docs for which clearly state “PiicoDev connector: I2C0 (SCL:Pin 9, SDA:Pin 8)”
Ahhgg
MPY: soft reboot
[11]
inizializing LC709203F…
LC709203F sucessfully inizialized!
IC version: 0x2afe
Battery: 3.873 Volts / 58.4 % Cell
Hey @Mark285907
Great to hear you got it working!
Only thing to keep in mind with the cross compatibility is that some qwicc sensors do require 5V rather than 3.3V but otherwise the world is your oyster.
So an electronics/battery engineer I am not so I find this hard to fathom.
I’ve got a weather station comprising:
  • Pico W
  • BME280 atmos module
  • This battery gauge
  • Adafruit Universal USB / DC / Solar Lithium Ion/Polymer charger - bq24074
  • Polymer Lithium Ion Battery (LiPo) 3.7V 4400mAh
  • 5V 1.2W Solar Panel - ETFE - Voltaic
The WS collates data and offer that up in HTML on request so 99% of the time it’s just sitting there doing noting other than waiting for a request. Part of the code writes the date, time, battery volts and battery % to a data file on the Pico hourly.
I would assume that the load would be very consistent (my Fluke 77 is not capable of accurately measuring this). I’ve had the WS running for 4 days from 95% charge to dead flat in mostly overcast and wet weather.
The graph below is for the 4 days. The up spike is a bit of sunshine. I expected the slow decline and end drop off in battery volts (shown as volts x 10 for scale on the graph). What I don’t get is battery percentage going from 95% to 10% in 2 days then 10% to 0% in the next 2 days.
Is there some critical point in volts that affects the module and its math?
I also log the wi-fi strength, temp, RH and pressure, calculated dewpoint and UVI. These numbers are very consistent throughout the 4 days which to me means the Pico was running as required right up to the end.
Hi @Mark285907
A few thoughts come to mind, i notice that the line for voltage is rather smooth, right up until the end where it drops off, usually you would see a sharp drop off between 100% at 4.2V and 90% at ~3.8V which doesn’t appear to be present in your graph.
I’m wondering if the wrong battery type has been selected and is skewing the results because of this.
Thanks Dan and you are 100% correct. The library is limited to 3000 mAh. I found this thread and post 17589 within that references a datasheet with hopefully has the correct hex number for my 4000 mAh.
https://forums.adafruit.com/viewtopic.php?p=944890#p944890
I’ll run another test.
Hi @Mark285907
Keep us in the loop with how it works with the new hex value entered. It would great to see your project working as you had wanted. :slight_smile:
So now I’d set the correct battery type and modified the library adding a 4000 mAh battery, I’m getting a better set of numbers. Still not perfect but a lot closer.
This is 4 days, 3 of which were sunny as you can see on the Perc plot.
Volts x 10 shown on the graph to better scale with the battery %.
Hey @Mark285907,
That looks more like it! Maybe a few little values to tweak to get it perfect, but that really depends on how accurate you need this to be.
The battery % above 80% stands out to me as unusual. I have pulled This Graph from another one of our forum posts on LiPo batteries for reference. I would expect a voltage reading larger than 4V to indicate a charge above 90%, but it doesn’t look like it is recording more than about 87% even at these voltages.
It does seem like you are getting a pretty accurate idea of the battery drain over time so getting this ‘perfect’ may be more effort than it is worth.
Thanks for keeping us in the loop!
Thanks Sam. Yes its accurate enough for a backyard weather station me thinks.
I did try to make some sense of the battery factors in the data sheet to tweak things but it was too deep for me.
