Does anyone know if this product can be linked to a 18650 BMS of three cells (~11-12V). Looking at the example code it looks like there isn’t an obvious way of setting initial voltage or current, but it could detect it I guess.
Hey Liam, yea I get that was thinking of using the CE09207 BMS, but as far as I can tell that doesn’t have a fuel gauge. I want some sort serial output to let me know how much charge the battery has. Would love it if you could recommend a solution.
Suppose you could use three of the MAX17048, and add the result together, but not even sure if that would work. It looks it connects to serial communication, so would image that you could only use one of them at a time.
but what it sounds like to me is that the fuel gauge is hooked up to one 18650 cell, assuming hooked into the BMS, and using that to approximate the usage across all cell.
Guess that could work if all the batteries are relatively the same, does that sounds right to you?
The module actually uses I2C, which can be setup with multiple devices.
BUT the problem arises when trying to measure the other cells, the GND pin of the first cell, bridges Vbatt1, the second module GND is connected to Vbatt1 - shorting out the battery
From a quick glance at the link they have 3 batteries in parallel, very different to series.
In parallel, the sum will act as one higher capacity, so we can measure the total charge of the pack.
Your setup has 3 in series, increasing the voltage - different story unfortunately.
Dialling things back a bit, whats your overall project? Is there a reason you need to monitor each cell?
A bit tangential but perhaps not. For larger batteries I normally use a voltage divider and a microcontroller. Just pick your resistances so you don’t fry your board and with a bit of maths you can get a voltage.
But as Liam asked, with some more info about your project we can work towards what’s best for you!
The links to " Adafruit’s Arduino or CircuitPython/Python library code" seem to be pointing to code for LC709203F. Is this the same as MAX17048 or a different product ?
can the MAX17048 be connected to JST connector on the PiicoDev LiPo Expansion Board for Raspberry Pi Pico so that it can also be charged? I’ve also cut the cable between the JST and the battery and put a switch on there so that the PICO can be turned on/off when there is no USB connected, but I want to be able to have the state of charge displayed on the device. Will this setup work?
