Core Electronics Forum
Adafruit NeoPixel UV LED Strip with 32 LED/m - White PCB - 1M (ADA3851)
#1
This is a placeholder topic for “Adafruit NeoPixel UV LED Strip with 32 LED/m - White PCB - 1M” comments.
What new iteration of NeoPixel strip is this? Roll out the black light and disco ball! It’s an Adafruit NeoPixel Ultraviolet Strip with 32 LEDs per meter! Each order … read more
#2
Regarding the Adafruit UV LED Strip (SKU: ADA3851). I see that this requires a 5V power supply. Could you use the 5V pin of an Arduino Uno instead?
#3
Hey Chris
The answer is yes, kinda. The current needed to run an Uno is fairly small compared to the ~2A that are needed for these lights so depending on the limits of the supply the Uno may struggle though if you get a supply that can handle the load you should be fine.
