Ada3851. Can we power these lights without the need for a micro computer… Just straight off a 5volt power supply?.
Meed help urgently
Hi Jesse,
Welcome to the forum!
You will need some kind of microcontroller to use those LEDs as they are addressable LEDs (Neopixels). I’d suggest taking a look at our tutorials on using addressable LEDs
If you want colour changing LEDs you will need a microcontroller - even if that’s a pre-built LED controller like this one:
Otherwise we’ve got some short strips of single colour LEDs:
And you could also look into using EL wire - Adafruit have a good tutorial here: https://learn.adafruit.com/el-wire
Regards,
Oliver
Support | Core Electronics
Hey oliver, we need uv for resin curing, we are hoping to run these ada3851 as easily as possible. In an urgent time
Hi Jesse,
This can be done quite easily, but you will need a microcontroller of some kind. Otherwise, you might like to just use something like these UV LEDs:
You might also like to check out this project:
Regards,
Oliver
