The VL53L0X is a Time of Flight distance sensor like no other you’ve used! The sensor contains a very tiny invisible laser source, and a matching sensor. The VL53L0X … read more
Hi, - in regards to the while/grey you speak of. Would this work detecting the contours of a persons face as i drag across a 6x8 grid (logging the distance at each grid square). or up to 60x80 grid even.
I am replicating a project of 3d scanning. i will input the values to its designated colour as a visual representation.
Many thanks.
P.s. I am using a micro:bit, using aduino software
P.s.s The device would be only maximum 10cm away from the face if this helps measure contours.
