What kind of voltages to you have to plug in? I wasnt able to find the exact section of the instructions where it says that, could you please send some pictures of the manaul?
It should if your required inputs range from DC 1.23 V to 30V, a 9V battery might work depending on the current you are looking to pull through the board, I would go with the 12V power brick.
That looks good, as long as you’re providing an appropriate input voltage and setup your adjustable supplies off the live circuit before adding them in (and they meet the limit of output current: 3A max) then you should be good to go
