I’d be interested to see how well the new Pi can utilise the two 4-lane CSI ports. Any chance of plugging in a pair of 4-lane TC358743 HDMI adapters and seeing how it performs as a H264 stream encoder?
That is a great use for the Pis that I haven’t even seen till now!
I think you may run into a few issues there trying to encode 2 separate video inputs. There will probably be more than enough bandwidth through MIPI - no issue there, but the Pi 5 is missing h264 hardware encoding (bit unfortunate). This is all done software side now and although it smashes the Pi 4 in terms of software-based encoding, I don’t think it will be enough to perform it on 2 inputs at once at a decent fps.
As of right now, the Pi 5 hasn’t been officially released yet. We aren’t taking pre-orders for the Raspberry Pi 5 until we’ve confirmed what stock is available, but you can click the “sign up to be notified” link on the Pi 5 product page and we’ll send you an alert as soon as we can take your order.
Oh wow, I didn’t even consider that there might not be hardware H264 encoding on the Pi 5. I was hoping for some extra headroom to play with but with software encoding performance might actually regress.
Yeah, it is a bit of a shame, think it was to help keep down the costs a little. Hopefully, someone figures out a workaround, or we just hope the Pi 6 is fast enough to effectively software encode ahahahah.
Yes. It’s always like that. The OS is shutdown and red light showing on device but heat sink is warm (not hot but warm). If I remove the power supply then it goes cold. I didn’t think I would need to physically detach the power supply on a Pi 5.
That is very odd, what heatsink have you got on it? I’m wondering if the power management next to the USB runs warm while the board is off, but I don’t think it would be that warm. Does your heatsink cover this? Also what power supply are you using?
I have just plugged one in and turned it off, will let it sit for a few hours and check it with the thermal camera.
I’m using the active cooler which is the fan and heatsink together. I’m using the Pi4 power supply which Core Electronics said was fine to use on a Pi5.
That is with our board powered off. I have just come across a post on Raspberry Pi’s forum where temps are being discussed. It is wide enough spread for me to believe its normal.
Has anyone measured how much current the Pi 5 is drawing when shutdown ??
Tested my Pi 4 and when shutdown about 200mA (1W). When running and idle about 400mA.
To me this is way too much power to be consuming when supposed to be off.
Another reason I choose a microcontroller (Pico, Arduino) over a microcomputer (Pi).
