Hi, I’m fairly new to electronics so apologies if this is a bad question.
Is there also a library that is compatible in the Arduino IDE for the PiicoDev-Air-Quality-Sensor-ENS160 so that it can be programmed in arduino C.
I would like to try and use this module with other boards like an esp32 etc.
Many thanks.
Hi Marcy,
Welcome to the forum!!
The fastest way to find an answer for different PiicoDev modules is to search for the chip name then ‘Arduino Library’ - see this search: ENS160 arduino - Google Search
You can actually run Micropython on the ESP32 - while PiicoDev doesn’t officially support ESP32 it does run!
