In this project there are 13 leds. Of those, 6 leds are not powered.
why is that so?
Thanks.
Hi @Brenton472
are you referring to this guide?
There are 8 LEDs being used, because this is an 8-bit shift register.
Yes it is! So how do the other 6 leds shown as unwired on the breadboard come into play?
Perhaps you are misinterpreting the diagram, which would be easy to do since it is a little cramped
There are a total of 8 LEDs in the above diagram
There are two groups of 4 LEDs, and each group is made up of alternating red and blue LEDs.
You can count the wires, which are also in two groups of 4
There are also 8 Resistors, one for each LED to limit the LED current.
Thanks, now I see what is going on.
If you need further info about 74HC595, you can see here: Introduction to 74HC595 - The Engineering Projects
Here you can find the pinout and all other necessary info regarding the chip.It is basically a shift register. It has an ability to store and to shift the data of 8 bits.
