Hi Every one,
This is my first post so apologies if I leave anything out, ill try make it as detailed as possible.
I have made a equatorial platform that tracks the night sky for my telescope and am using an arduino powered stepper motor to try and get the precise and smooth speed I need.
I have been having some slight issues with the motor seeming to speed up and slow down and just want to confirm if i’ve made any errors in my set up. Although I would like to point out the speeding up and slowing down may be quite minor but exaggerated due to high magnification of the telescope. overall the speed is correct and can keep an object in the field of view for 1.5 hours but the fluctuations are happening back and forth within the center of the field of view. (i hope this makes sense)
Currently I’m using a single 12v 2A power source that supplies 12v through a decoupling capacitor - 100UF/25V to the stepper driver set set at 1.4A (have tried both DRV8825 and S109 driver) and also splits before the capacitor and goes to a buck converter that reduces voltage to 5v to power the arduino Micro via the 5v pin which i recently switched to from a nano for the extra accuracy of crystal oscillator.
The Arduino sketch runs the motor at 32 micro steps to reduce vibration at high magnification (testing shows no difference between 16 or 32 micro steps) and loops taking a single step at 1 step every 6032 micro seconds.
Could the single power source be causing an issue? or does anything stand out?
looking forward to your response.
Greg
