Hi All,
I have a little project with an Arduino and stepper that I use for astronomy. I use this exact set up on multiple devices and many others use the exact set up successfully too.
Now, i’m currently assisting a gentlemen in the states to set it up but i’m having some issues and hoping the forum can assist.
some info about his set up.
sketch: my sketch no issues on 12+ other projects.
Wiring: from video calls i’ve had with him everything is wired correctly.
Arduino Uno - temporary for his first prototype.
stepper: TB6600
motor:
- Motor Type: Bipolar Stepper
- Step Angle: 0.035 deg.
- Holding Torque: 4Nm
- Rated Current/phase: 1.68A
- Phase Resistance: 1.65ohms
power supply to driver :12V
Issue:
Motor vibrates but does not turn, but it is the testing that’s interesting. please see below different combinations and results.
tb6600 set to 2 amps and 32 micro steps and motor connected
- motor does not turn
- voltage measured at power input is showing 8.6 volts instead of 12 volts.
tb6600 set to 2 amps and 32 micro steps but the motor is disconnected
- voltage measured at power input is correct 12 volts.
tb6600 set to 0.5 amps and 32 micro steps and motor connected
is there a reason the voltage drops when the motor is connected at 2 amps also happens at 1.5 amps, should this be happening? Also interesting to note voltage stays correct when tb6600 set to 0.5 amps.
The stepper has to step extremely slow so we did some further testing at the extremely slow speed and higher speed to see if there was a difference.
slow speed: 1 step every 22471 micro seconds
fast speed: 1 step every 224 microseconds.
tb6600 set to 0.5 amps and 32 micro steps motor running at slow speed.
- motor vibrates but doe not turn
tb6600 set to 0.5 amps and 32 micro steps motor running at FAST speed.
-Motor turns fine!
So in summary we can get the motor to turn fine when TB6600 set to 0.5 amps and 32 micro steps running at FAST speed. There is no other combination of amps or microsteps that makes the motor turn.
I hope this information is enough.
In summary, why is the voltage dropping to 8.6 when tb6600 is set to 1.5 amps or higher and motor connected, is this normal?
why will the motor only turn when set to 0.5 amps and a quicker speed?
thanks for your help.
