Discover the Argon NEO 5 Raspberry Pi 5 Case, a robust aluminum alloy case offering passive cooling and easy assembly. Enjoy its sleek black & red finish while ensuring your Raspberry Pi 5’s safety and portability.
Does the case provide any cable routing for access to the GPIO pins when the lid is on? It’s a bit hard to tell from the photos but I’m assuming the small grid on the side near the GPIO header is just for airflow?
This case doesn’t have a way to access the GPIO pins when fully assembled, but does have a removable panel on the top that you can take off to access the GPIO.
The Pi will look similar to the following screenshot when this panel is removed.
