I have followed the steps suggested in https://github.com/goodtft/LCD-show. I installed the 3.5” RPi Display (MPI3501) driver and after the RPi reboots, the screen shows the booting process for a few seconds, then it becomes white. After a few more seconds, the RPi desktop is shown for a couple of minutes and the end it becomes white again.
If I reboot the RPi, the screen has the same behaviour, but there are some times that the screen does not work at all, it is always in white.
In any of both cases, I can successfully SSH and VNC the RPi. I can see the RPi desktop in my windows computer through VNC.
Hi, thanks for the reply. The problem was power, so now the display is working properly. Now, I’m trying to connect the display to a breadboard. I would appreciate if you help me with the wiring.
You should be able to work out how to wire it to the breadboard by using the GPIO diagram to match the positions to where they go. As you are using a display I do not have the wiring diagram for I can’t say exactly which pins are being used but you should be able to work it out once you have them all wired in.
