I need to add audio and mic to a Rpi zero 2W running under battery. the small usb mic I think will work, I ordered but haven’t arrived yet. about the speakers, I need a really low power solution, I don’t need too much volume neither super good quality audio.
You could try using this USB Audio Adapter along with a micro‑USB OTG adapter to connect it to the Pi Zero 2W. It looks like a good low‑cost option for your setup, though you might want to double‑check compatibility for your specific use case.
I think by the time you muck around with exotic bits to get a 3.5mm jack and then plug an amplifier into that you might find that you will be up for a similar amount if not more
False economy methinks just to save a couple of bucks.
I understand that it is not much money, and if it were for me, I wouldn’t care, but the project has a budget, and with this device, we’re exceeding it.
