What formula can I use to work out that I am using the correct 7 core cable for my system and also determine its voltage drop?
With the 7 core cable the solenoid only uses two wires one for +24 and one for GND, the other 5 are used for USB to Arduino. The 7 core cable is incased in corrugated tubing. I do need the external diameter of the 7 core cable to be less than 6 mm if possible, no larger than 7 mm. Voltage drop between 1- 3%.
Solenoid Specifications:
Volts: 24 VDC
Solenoid Temperature: 14 Celsius maximum
Resistance: 15 ohms
Amps: 1.6 Amps (I am using a 2 amp power supply with an additional 3 Amp fuse wired to the solenoid)
Length: 1 meter is the 7 core cable + & - then from GX16 to DC socket is a 1 meter 26 AWG wire for + & - (not sure if correct to use 26 AWG)
Cable Specifications (need to determine if these are the correct specifications):
Cores: 7
Wire Gauge: 24 AWG
Conductor Area CSA: 0.2 mm²
Max Recommended Current: 1.75 Amps per conductor @ 25 Celsius
Max Operating Voltage UL: 300 V RMS
The 7 core cable is in corrugated tubing.
