This is a placeholder topic for “Breadboard-friendly 2.1mm DC barrel jack” comments.
This power jack is designed to fit 2.1mm power plugs snugly and securely. Perfect for adding a power connector to your project. Adafruit went for the more expensive "thin … read more
How do you mount this on a bread board? it has 3 pins, which one is the ground and which one is Voltage? Thanks in advance
Hey Daryoush,
Good news! The datasheet has all the answers once again!
I’ve drawn in the polarity for a centre positive source (like most plug packs around these days), and you can see which pins this carries through to on the board.
Seems our product image is quite sensible:
All the best with your project!
Thank you James ,
