How do I go about soldering the following DC Power Jack.
Tabs 2 and 3 beep when checking continuity.
Tabs 4 and 5 beep when checking continuity.
Tab 1 = VCC
Tab 2 = GND?
Tab 3 = ?
Tab 4 = ?
Tab 5 = ?
Tab 1 = VCC
Tab 2 = GND?
Tab 3 = ?
Tab 4 = ?
Tab 5 = ?
Hey! Welcome to the forum!
Good news, the info you need is right in that datasheet!
Hope this sorts you out!
Thanks mate! If you don’t mind to confirm the following.
Hey,
If you have the plugpack you are going to use handy it might be worth connecting that one up to confirm the pins. and testing with a DMM.
In PCB manufacture there is lots of ‘do this but also this’ and depends on the situation. Grounding the shield is usually a safe bet. Most ECAD software will have rules depending on how you defined each pin (if you made separate pins for each through-hole then you’ll have to make a link on the schematic so you can link it).
Making a ground plane is generally good practice: there’s some good discussion on this weeks Factory EP: The Factory | Testing High Frequency SMT Protoboards - YouTube
Hi ss2
I think you should insert a mating plug and check again between the plug and pins with the plug inserted.
You may find tat pin 2 is the centre pin and pin 1 is ground. The continuity between pin 2 and 3 is a built in switched (closed with nothing plugged in) and opens when the plug is inserted. For a power socket ignore pin 3.
I could be wrong here but looking at the pic pin 1 seems to be connected to the outer connection of the plug (ground). So please insert a plug and check again.
From the continuity test the following beep together, should the following be okay?
Hi ss2
It would appear I was wrong. When I looked at your other pics I thought I was looking at the front of the socket not the rear. You can connect pin 2 and 3 or ignore pin 3 altogether. The internal switch is not used in your application.
Hey,
As mentioned before; it will depend on how you want it to work, it shouldn’t matter which ones you have hooked up (unless you need to move more current through the connector).
Oh yes it does
Dunno what I was thinking when I wrote that ![]()
The confusing thing about these kind of sockets is the GND is the switched signal. (pin 2 & 3)
Physically it is the easiest way to do it.
Have been caught out by these sockets in the past. My electronic theory says the +ve signal should be switched.
The diagram bottom right shows electrically how the signals are connected. When a cable is plugged in pins 2 & 3 disconnect. The GND of the cable is connected to pin 2, the +ve is connected to pin 1, pin 3 is not connected. When the cable is removed pins 2 & 3 connect again.
The idea behind this design is the GND of an internal battery (or some form of power supply) is connected to pin 3. The circuit GND is connected to pin 2. So when a cable is plugged in the power comes from the cable, when removed the power comes from the internal battery or power supply.
Anyway, cheers
Hi All
Could also be used to alert a device that external power is removed.
For this application however I think it would be best to ignore pin 3 and save confusion.
