Camera cables
Do Raspberry Pi Camera FPC Adapter Cables fit between Pi 4 and Raspberry Pi HQ cameras? Or are they only for PI 5 . Thanks
Hey @Frank196078,
The Pi 4 and 5 have different connectors for camera on the board. The Raspberry Pi Camera FPC Adapter Cable will only work with a Pi 5 as it doesn’t have the right connector type to interact with a Pi 4.
If you are looking at a Raspberry Pi High Quality (HQ) Camera, it should come with the correct cable for a Pi 4 setup.
Otherwise, if you need a new cable to work with the HQ camera and a Pi 4, this one should do the trick:
Hope this helps!
