Can the LED on PiicoDev sensor be turned off?
Short of using a bit of gaffer tape, just wondering if there is a command to toggle the LED off? I didn’t see any reference in the PiicoDev library.
It’s a nice to have, as it is quite bright. Thanks.
Hi Jono,
There is a trace on the rear of the PCB you can cut to disable the power LED (and solder pads to bridge if you want to reenable it later). @Michael mentioned it in another PiicoDev thread I’ve linked below.
Thanks @Spookee!
FYI, Michael actually tossed up making it software switchable on the glowbit module, but decided against it:
