I am running a PiicoDev Capacitive Touch Sensor CAP1203 on a Raspberry Pi 3A. When running the example script (main.py) using python3, I am getting an error: Device ID does not match PiicoDev CAP1203
Now first of all I though it was my bad code, but I am also getting this error with the example code… the script still runs, should I ignore or is it something simple I should fix.
Hi @Shannon. We have been able to replicate the issue. You are right, scripts still run fine.
It’s an erroneous message that doesn’t effect the operation of the touch sensor. We will be rolling out a fix for that message in the near future.
@Shannon I’ve suppressed the device ID check to patch this annoying message. For some reason the check worked fine on RPi Pico, but didn’t play well with Raspberry Pi (Single-board computer)
In any case, its suppressed because it doesn’t appear to offer any real value
Update your piicodev package (0.0.13) and you shouldn’t see it again. (Tools > Manage Packages > piicodev > upgrade) You may need to select the ellipses (…) to select the correct version
