Michael just shared a new tutorial: "Create an installer script for Raspberry Pi"
After lovingly crafting your project on a Raspberry Pi, you might want to share it with the world. The easiest way is of course just to publish a list of the commands that you executed to get everything up and running. For complex projects, this…
Thanks for creating this article! It’s pretty useful to learn how to streamline some of these setup tasks. I’m assuming the first thing is to get internet connection. I guess if you are starting from a fresh SD card, the internet connection could be achieved by adding a few lines in the installer script to edit the wpa_supplicant file before running the apt-update/apt-upgrade commands.
Would you please explain how to add lines to configure some of the settings in Raspi-Config (e.g. expand memory, change keyboard, and time zones)? Can those settings be changed via command line the same way you change the config.txt file?
