They would have been great, if I’d known they existed, and if I knew that’s what I needed. Since my original post, I bought a couple of the the pico HAT Hacker sas I’m sure they’ll come in handy, and they’re pretty cheap
Getting here was quite a journey getting to where I am with it. I shared a link to the first version, FLIRC case, zero2w, configured as a smart USB gadget, and an inkyPHAT to show device details. I just wanted to add some buttons.
My first attempt was to try to connect to the unused headers under the hat. My first mistake there was forgetting to mirror the pins as I was looking underneath. After that I had it “kind of” working, but it was a bit fragile.
Then I realised the buttons and addressable LED chould be attached to the case and I could just connect to the pi’s pins directly. Also a bit of a pain, so I decided on a third row of pins bridged to the pi’s pins, then several attempts at that.
After all that was when I discovered the pico hat hacker. The biggest (and self imposed) constraint has been fitting it in the FLIRC case. Not a lot of room, and it’s got a built in heat sink on the processor, then I have to fit the button board under the inky PHAT above the case.
Thinking it through, if I was going to start again… a trimmed down Pico HAT Hacker overlapping the pi, then cutting a hole in the FLIRC case to allow headers through (removing the heatsink), then connecting that to the button board like that would have been heaps eaisier. I guess I could have also used a different case too.
I’m more of a software guy, but I’ve been enjoying playing with the hardware.
They say necer trut a programmer with a screwdriver, I’ve got a soldering iron
