I tried to post on forum but could not work out how to encapsulate the code:
LIS3DH interface
It is unclear to me which pins of the sensor need to be connected Clk. D, CE to which pins of the MAXIM board in these examples and is this using I2C or SPI communication. ??? And do they use different pins for each type of communication? This is a simple question but I have no idea how to easily navigate the code to find out and how to change the pins for same function.
// Basic demo for accelerometer readings from Adafruit LIS3DH
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// Used for software SPI
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
// Used for hardware & software SPI
#define LIS3DH_CS 10
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
#define Serial SerialUSB
#endif
void setup(void) {
#ifndef ESP8266
while (!Serial); // will pause Zero, Leonardo, etc until serial console opens
#endif
Serial.begin(9600);
Serial.println(“LIS3DH test!”);
if (! lis.begin(0x18)) { // change this to 0x19 for alternative i2c address
Serial.println(“Couldnt start”);
while (1);
Serial.println(“LIS3DH found!”);
lis.setRange(LIS3DH_RANGE_4_G); // 2, 4, 8 or 16 G!
Serial.print("Range = "); Serial.print(2 << lis.getRange());
Serial.println(“G”);
void loop() {
lis.read(); // get X Y and Z data at once
// Then print out the raw data
Serial.print("X: "); Serial.print(lis.x);
Serial.print(" \tY: "); Serial.print(lis.y);
Serial.print(" \tZ: "); Serial.print(lis.z);
/* Or…get a new sensor event, normalized */
sensors_event_t event;
lis.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("\t\tX: "); Serial.print(event.acceleration.x);
Serial.print(" \tY: "); Serial.print(event.acceleration.y);
Serial.print(" \tZ: "); Serial.print(event.acceleration.z);
Serial.println(" m/s^2 ");
Serial.println();
delay(200);
// Basic demo for tap/doubletap readings from Adafruit LIS3DH
#include <Wire.h>
#include <SPI.h>
// software SPI
// hardware SPI
// I2C
#endif
// Adjust this number for the sensitivity of the ‘click’ force
// this strongly depend on the range! for 16G, try 5-10
// for 8G, try 10-20. for 4G try 20-40. for 2G try 40-80
#define CLICKTHRESHHOLD 80
void setup(void) {
#ifndef ESP8266
#endif
Serial.begin(9600);
Serial.println(“Adafruit LIS3DH Tap Test!”);
while (1);
lis.setRange(LIS3DH_RANGE_2_G); // 2, 4, 8 or 16 G!
// 0 = turn off click detection & interrupt
// 1 = single click only interrupt output
// 2 = double click only interrupt output, detect single click
// Adjust threshhold, higher numbers are less sensitive
lis.setClick(2, CLICKTHRESHHOLD);
delay(100);
void loop() {
uint8_t click = lis.getClick();
if (click == 0) return;
if (! (click & 0x30)) return;
Serial.print(“Click detected (0x”); Serial.print(click, HEX); Serial.print("): ");
if (click & 0x10) Serial.print(" single click");
if (click & 0x20) Serial.print(" double click");
Serial.println();
delay(100);
return;
