Does not see libs in Python
Following a rebuild & OS upgrade etc. I see the way to access the ADC card has changed.
Followed all the instructions…
Loaded the libs
Loaded smbus2
but get this error when running the demo demo_logvoltage.py.
What have I missed?
Matthew
dewoepsm@raspberrypi:~ $ python ADC-All.py
Failed to import ADCPi from python system path
Importing from parent folder instead
File “/home/dewoepsm/ADC-All.py”, line 22, in
from ADCPi import ADCPi
ImportError: cannot import name ‘ADCPi’ from ‘ADCPi’ (/usr/local/lib/python3.9/dist-packages/ADCPi/init.py)
During handling of the above exception, another exception occurred:
File “/home/dewoepsm/ADC-All.py”, line 29, in
File “/home/dewoepsm/ADC-All.py”, line 31, in
raise ImportError(
ImportError: Failed to import library from parent folder
Fixed my own issue - Need to enable IC2 interface…
Hey Matthew,
I have run into similar problems countless times where its something not being enabled that inhibits everything from working. Glad to see you got it all sorted though!
Blayden
