and was able to get a local copy of the repo without any issue. Seems it may be an issue with your local OS that you’ve got set up. Can you please run the following and check the version of git that you’ve got installed locally? We may need to ensure that some packages are up to date:
to confirm that it certainly points to /usr/lib/git-core it’s likely not the issue, but thought I’d check in case there’s something else going on with the configuration here.
How strange, let us know if you run into any issues with that, also, does that occur when trying to clone any repo, or just https://github.com/SensorsIot/IOTstack.git specifically? And can you create repos locally by running ~$ git init and set up a remote origin for it, or is that functionality broken too?
