I am having installation issues with raspberry pi
I keep getting unmet dependencies despite updating/upgrading the system regularly
I use raspbian and have been able to instal packages in the past but now seem to get these errors all the time. Here is an example
pi@raspberrypi:~ $ sudo apt-get install minicom lsof
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt-get -f install’ to correct these:
The following packages have unmet dependencies:
libavresample-dev : Depends: libavutil-dev (= 6:11.12-1~deb8u1+rpi1) but it is not going to be installed
libjpeg62-turbo-dev : Depends: libjpeg62-turbo (= 1:1.3.1-12) but 1:1.4.1-2 is to be installed
lsof : Depends: libperl4-corelibs-perl but it is not going to be installed or
perl (< 5.12.3-7) but 5.20.2-3+deb8u11 is to be installed
E: Unmet dependencies. Try ‘apt-get -f install’ with no packages (or specify a solution).
appreciate any help!
