ESP32-S3 1.8inch AMOLED Touch Display Development Board (No Battery) (WS-29958)
This is a placeholder topic for “ESP32-S3 1.8inch AMOLED Touch Display Development Board (No Battery)” comments.
A pocket-sized dual-core board pairing a vivid 368×448 AMOLED touchscreen with six-axis motion sensing and onboard audio.
Need a battery MX1.25 for the amoled ESP32 dev board & screen - do you sell or can you recommend where to source ?
Hey there, @Lee331470, and welcome to the forum. Glad to see here you here.
At this time, we do not have any LiPo cells with the MX1.25 connector. All our LiPo cells currently use JST-PH connectors. Apart from Waveshare themselves, I don’t know anywhere else that would supply a battery with a molex connector.
Alternatively, you could splice a suitable 3.7 V LiPo onto our 1.25 mm 2-pin Molex PicoBlade-compatible cable. Obviously this can be risky for the device, so I’d recommend treading carefully and verifying positive and negative against the board markings with a multimeter as you go. But if you feel comfortable and take you time doing the cutting, joining, and heat shrinking of the wires, you should be golden.
