I am looking to make a smart watch with a display to tell the time and a heart rate monitor. I don’t want to use a micro bit to do it as they are a bit clunky.
My online research has pushed me in the direction of an ESP32 based watch but it seems to be very complicated in terms of ordering and securing components.
Does anyone have any ideas on what I could use to make this happen?
I keep seeing this surprisingly affordable weird circular display with the popular RP2040 micro controller built in. Looks like a big digital watch.
It would be able to interface with this gravity heart rate monitor thing no worries.
I’m imagining the screen on the top of the wrist and the sensor on the bottom of the wrist. Both attached the the same band.
I’m sure there are cleaner ways to do it, but I like the simplicity.
It’s the right amount of challenge for a school project in my opinion.
Does that feel doable to you?
I spoke to the guys at core electronics and they said that the one you mentioned is a little difficult to use.
They steered me to this one:
The only problem with this one is that it has a weird battery connector so I think I will replace that on the board to a standard one.
We usually use Arduino but these kids haven’t done any programming so it won’t matter. Dan from Core Electronics has written some code for that module as well so we should be able to get it going.
This should be a great board with your project. A monitor like this one the underside of the board could give you a really sleek compact design. The one you’ve selected is much more cost-effective though, we look forward to seeing ti in action.
I’m no expert and it has taken me several days to get the watch to display an image, display a gif, display the time and react to touch at given coordinates. All of that is working correctly and I have learned a lot about how it works.
I am trying to get stable readings off the biometric sensor I purchased and am struggling to get it to work correctly. I am getting readings off it but they are bouncing around a lot. I have tried using 4.7k resistors between SCL and 3.3V and SDA and 3.3V but that didn’t help. I have defined the SDA and SCL pins correctly and the sensor is registering but the values are incorrect. If they’re not, I’ve got a serious case of arrhythmia!
I haven’t tried the logic converter board I purchase as the Internet and Chat GPT seem to think it is not needed. I did have it giving me a fairly accurate reading but now it is giving me all sorts of strange reading despite the wiring being identical.
Would this been normal behaviour if I was using the incorrect logic level?
I will see try the logic level converter but if that doesn’t solve it, I will either need to get a different sensor or do something different with the one I have.
The issue with the bio-sensor sounds strange. Can you send pictures of your physical setup, as well as code snippets? That should shed some light on the exact setup you’re working with right now.
I think I might be totally confused as to how to hook this all up.
I’ve got:
3.3V of the ESP32-S3 hooked up to VIN on the sensor.
GND to GND
GPIO Pin 15 to SDA
GPIO Pin 16 to SCL
The code I am using is an example from the Sparkfun Library.
Optical Heart Rate Detection (PBA Algorithm) using the MAX30105 Breakout
By: Nathan Seidle @ SparkFun Electronics
Date: October 2nd, 2016 https://github.com/sparkfun/MAX30105_Breakout
This is a demo to show the reading of heart rate or beats per minute (BPM) using
a Penpheral Beat Amplitude (PBA) algorithm.
It is best to attach the sensor to your finger using a rubber band or other tightening
device. Humans are generally bad at applying constant pressure to a thing. When you
press your finger against the sensor it varies enough to cause the blood in your
finger to flow differently which causes the sensor readings to go wonky.
Hardware Connections (Breakoutboard to Arduino):
-5V = 5V (3.3V is allowed)
-GND = GND
-SDA = A4 (or SDA)
-SCL = A5 (or SCL)
-INT = Not connected
The MAX30105 Breakout can handle 5V or 3.3V I2C logic. We recommend powering the board with 5V but it will also run at 3.3V.
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
void setup() {
Wire.begin(15, 16); // define the SDA / SCL pins
Serial.begin(115200);
Serial.println("Initializing...");
// Initialize sensor
if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
Serial.println("MAX30105 was not found. Please check wiring/power. ");
while (1)
Serial.println("Place your index finger on the sensor with steady pressure.");
particleSensor.setup(); //Configure sensor with default settings
particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
void loop() {
long irValue = particleSensor.getIR();
if (checkForBeat(irValue) == true) {
//We sensed a beat!
long delta = millis() - lastBeat;
lastBeat = millis();
beatsPerMinute = 60 / (delta / 1000.0);
if (beatsPerMinute < 255 && beatsPerMinute > 20) {
rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
rateSpot %= RATE_SIZE; //Wrap variable
//Take average of readings
beatAvg = 0;
for (byte x = 0; x < RATE_SIZE; x++)
beatAvg += rates[x];
beatAvg /= RATE_SIZE;
Serial.print("IR=");
Serial.print(irValue);
Serial.print(", BPM=");
Serial.print(beatsPerMinute);
Serial.print(", Avg BPM=");
Serial.print(beatAvg);
if (irValue < 50000)
Serial.print(" No finger?");
Serial.println();
I have also tried this code from a Max 30102 library:
@file Max30102.ino
@brief Checks the Heart Rate and SpO2
@detail Checks the Heart Rate and SpO2 using Max30102 sensor
* Reference arduino code: https://github.com/bobdavis321/Arduino-MAX30100 , https://www.youtube.com/watch?v=mmXJ33Nx4Mc
* Refrence aries board: https://vegaprocessors.in/blog/interfacing-max30102-pulse-oximeter-to-thejas-soc/
* MAX30100 sensor
* Device address -0x57
* Connections:
* MAX30102
* 3V3 - 3.3V
* GND - GND
* SDA - SDA0
* SCL - SCL0
* Note:
* Use 10K pull-up resistors while connecting SDA and SCL pins to MAX30102 sensor for accurate measurements.
#include <Wire.h>
#include "MAX30102_PulseOximeter.h"
#define REPORTING_PERIOD_MS 1000
// PulseOximeter is the higher level interface to the sensor
// it offers:
// * beat detection reporting
// * heart rate calculation
// * SpO2 (oxidation level) calculation
PulseOximeter pox;
uint32_t tsLastReport = 0;
// Callback (registered below) fired when a pulse is detected
void onBeatDetected()
Serial.println("Beat!");
void setup()
Wire.begin (15, 16);
Serial.print("Initializing..");
delay(3000);
// Initialize the PulseOximeter instance
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
} else {
Serial.println("SUCCESS");
// The default current for the IR LED is 50mA and is changed below
pox.setIRLedCurrent(MAX30102_LED_CURR_7_6MA);
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
void loop()
// Make sure to call update as fast as possible
pox.update();
// long irValue = pox.getHeartRate();
// Asynchronously dump heart rate and oxidation levels to the serial
// For both, a value of 0 means "invalid"
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
Serial.print("Heart rate:");
Serial.print(pox.getHeartRate());
Serial.print("bpm / SpO2:");
Serial.print(pox.getSpO2());
Serial.print("%");
// if (irValue < 70)
// Serial.print(", No finger?");
Serial.println();
tsLastReport = millis();
Neither are working reliably. I have no idea what the issue is. If I do need the logic converter, how do I hook it up?
I would think you don’t need the logic level converter, the quote from Nathan at Sparkfun should be a fairly confident source.
Your connections seem fine in theory, though I believe the default i2c pins are GPIO21 for SDA and GPIO22 for SCL. Could be worth changing to test, though given that you are getting any readings at all, the device is likely transmitting something.
Can you provide an example of the output you’re receiving?
I can’t get the output or test the default pin definitions at the moment because I’ve left work and my computer is there (speech night tonight). I should be able to get accurate data tomorrow.
It was giving me a BPM that was rarely in normal human range i.e 17 BPM and it would return the same value over and over again. Then it would jump to 50, maintain that reading for a while then change again to something else. If I took my finger off altogether, it correctly read that my finger was off.
I tried it on my fingers and wrists, all with similar results. I also tried flipping the SCL and SDA pins. I even tried testing it on other people.
It’s strange because it is hooked up the same way on lots of different tutorials.
I don’t know much about it but apparently it is measuring the difference in light. It is as though the logic level is not high enough i.e. the signal is too weak. I am most likely totally wrong about that too.
I am keen to try the logic converter but I have no idea how to hook it up. It appears to want a 5V line but I don’t have one. The board is powered by a 3.7V battery although I have it hooked up to the computer at the moment.
Since the sensor is getting data out, I would say it is definitely working, no need for the logic level converter. The ESP32 is quite a fancy board, allowing you to use any pins for I2C, no need to move pins.
Behind the scenes the library is doing a lot of math, so that would explain some of the readings not coming through as expected, the second screenshot in that list of 3 look promising, there might have been a good window in there where it got a good set of readings.
Thanks Liam. I think you are most likely correct. I put it on with a rubber band and it gave me a much more stable reading. I think I will just move ahead with it as a project and if it gives the kids the wrong heart rate then so be it
Thanks again. My next phase is to get the bpm to update on the screen and to wake up the sensor when it is required. I am going to assume that the sensor should be off when not in use to save battery. Is that correct? I don’t even know if it is possible to control when it is awake and when it is asleep. Could I attach the power to one of the GPIO pins and make the pin go high when I want to use the sensor? I know it has an interrupt pin but I don’t know if turning it on is what it is used for. Does anyone know how to turn it on and off?
In an ideal world, I also want to use the accelerometer to turn the watch face on when you raise your hand. Hopefully I can get that working. That will save a lot of battery I would think. If anyone has advice on that, let me know.
Glad to hear you are making some ground!! To correct it a bit, you could always run a few tests - if you get a smart watch or phone capable of getting heart rate, compare to the output, and try a linear scaling, I would go as far as the offset and gain.
Depending on the library you are using updating the number/graphic on the screen will be a breeze compared to any sensor integration.
Battery life is a fuuuun one!!
First of all, putting your microcontroller to sleep will save the most power, this can be done easily in code (and especially the Arduino language).
Like you mentioned, along side this - putting any sensors and devices to sleep is great, thankfully this device lets you do that in software as well
The interupt pin is controlled by the sensor, when configured, this pin will turn on when something happens in the sensor - but not strictly necessary for your project.
A couple bits of advice on saving power, without having all of the right tools (Otii, Nordic) optimisation will be hard, and its worth taking one from the books of Fitbit etc, I belive they regularly check heart rate, sleeping in between, but they would keep the sensor on if the user is entering a high rate of change (logging), then only sending to the screen/smartphone when required. (For your project a button would be a great start, and will let you translate into the IMU later)
The Sparkfun library includes shutDown() and wakeUp() for the MAX30105, so you should be able to use that to control the power. sparkfun/SparkFun_MAX3010x_Sensor_Library
I’ve been battling away for some time trying to create the smart watch I described.
I’ve gotten to a point where I’m fairly happy with it.
Features I was able to include:
Time
Heart Rate Sensor
Pedometer
Countdown Timer
Stopwatch
Auto-sleep after 2 mins
Sleep from home with down swipe
Wake with up swipe.
I’m not an expert in anything but Windsurf AI made it possible.
The band is laser engraved and the casing is 3D printed.
Students will design their own faces on Photoshop. They will need to convert them using Image2LCD. Once they’ve done that, if they save it as the same file names as I used for the images, they will just need to replace the file in the folder I give them and the images will work.
Students will also design the outside of the watch housing. The internals will be provided as a Fusion template as it has taken a long time to get it to be the correct size.
I need to add a power switch as I am having some issues with the watch stalling and I need to be able to disconnect the battery to fix it.
As I have told the students, we are not Apple and we get what we get and we don’t get upset.
This is so great. I have been struggling with the same project. I am using a MAX30102 Module along with a Xiao ESP32 C3. I have not yet used the rubber band method to maintain constant pressure I’ll have to try that. Along with BPM I was also hoping to get SPO2 data. However the data inaccuracy is significant
