FireBeetle ESP32-E, specially designed for IoT, is an ESP-WROOM-32E-based main controller board with dual-core chips. It supports WiFi and Bluetooth dual-mode communication…
Great observation! Thanks for making us aware. Unfortunately that is a problem DFRobot is going to have to get fixed up, hopefully they get it sorted soon! In the meantime we will direct people to your fix if they contact us with that issue.
@lia262073 i couldn’t find anything explicit about compatibility - but I did find a github issue where somebody was having an issue (not compatibility related) using FreeRTOS with their WROOM-32E.
So signs point to probably yes!
I have some FreeRTOS based projects ahead. Could you please tell me which version of the ESP32 will be the safest choice? What about ESP32 WROOM DEV KIT-1?
I can’t confidently say exactly what will be the most likely to work without referencing an existing source. I haven’t delved into the minute differences between each variant, but it seems like any ESP32-based board should be fine!
If it helps, I found this great-looking series for getting started:
Perhaps work backwards from the hardware they select in video # 2 if you want to follow it exactly. It looks like they use a custom dev board, but the device variant is selected at 11:40
