FireBeetle Covers-Gravity I/O Expansion Shield (DFR0483)
This is a placeholder topic for “FireBeetle Covers-Gravity I/O Expansion Shield” comments.
DFRobot FireBeetle series is the low-power consumption micro-controller intentionally designed for Internet of Things (IoT). The series micro-controllers aims at…
Is this product compatible with the FireBeetle 2 ESP32 C6 IoT Development Board? Does the FireBeetle 2 board include headers so this expansion board can be plugged straight into it?
Hi @Thomas270345, Welcome to the forums.
It looks like the pinout between the FireBeetle 2 ESP32 C6 and the FireBeetle Cover are very different to each other so they aren’t compatible.
The Cover does come with the header and pins to be soldered to the boards so they can be connected together
Great, thanks Aaron!
I later found out this is the expansion board to use with FireBeetle 2 boards…
Gravity IO Shield for FireBeetle M0 and ESP32-E (DFR0762)
Hey Thomas,
Great Find! that should work well for you. Let us know if you run into any more hurdles.
