OK, some photos and code.
- main1.py (copy to main.py when you want it to boot)
- WAP.py Wireless Access Point
- audio.py Makes beeping noise when going up in lift (A joy to a pilot!)
- sensors.py Sets up and read the pressure sensors Barometer (Altitude and Vario), and ASI
- gpsuart.py Sets up uart and manages the GPS data
- lxnav.py LXNAV protocol sentence generator, returns the assembled string.
If I write a class or even just a bunch of code in a file, I try and leave an “Example of usage” at the end of the file, this can be used to demo/modify/develop the code in the file above it. But don’t forget to comment it out again.
(Also I find it good to help refresh my fading memory!)
There is also a lot of hardcoded setup in this these would be best moved to passed args in the startup of main1.py. But I have left it this way for clarity.
main1.py
## XCsoar WiFi Data Dongle
## main file.
## This starts up all the parts
## and then does the final part of sending data to XCSoar
## Written specifically for the RP PICO-W
## could run on an ESP32 or similar,
## but the audio tone generator will need to be ported to an ISR,
## as this uses the PICO PIO module
## sensors run in a _thread on core1 (PICO specific as it has 2 cores)
## but _thread works on the ESP32 as well
## If changing hardware arrangement,
## remember to update sensors and gps to any new pins used
## Code has been written to be as simple as possible
## Low level imports
import machine
from machine import Pin, Timer
import time
import sys
## Application specific imports
import sensors
import lxnav
import gpsuart
import WAP
import audio
## some links that may be useful
#https://forums.raspberrypi.com/viewtopic.php?t=310062
#https://hackspace.raspberrypi.com/articles/raspberry-pi-picos-pio-for-mere-mortals-part-3-sound
## for development, this will try and #######
## end the process neatly #######
button = Pin(0, Pin.IN, Pin.PULL_UP)
global loop
loop = True
timer = Timer(-1)
def checkButton(t):
global loop
if(button.value() == 0):
loop = False
timer.init(period=100, mode=Timer.PERIODIC, callback=checkButton)
# Should exit a booting "main.py", on power up, hold the "button"
time.sleep(0.5)
if(loop == False):
print("Exit")
sys.exit()
## define the parameters that setup the network and hardware
# Wireless Access Point WAP
ssid = "W-ap"
password = "123456789"
## startup the various parts
print("Starting Systems")
aud = audio.audio()
aud.doStartBeep()
ap = WAP.wap(ssid, password)
gps = gpsuart.gpsUart()
sensors.startSensors()
lx = lxnav.LXNAV() ## the protocol format in which to send the data to XCsoar
print("All started")
message_to_xcsoar_udp = ''
time.sleep(2.0)
aud.doStartTune()
a = 0.0
v = 0.0
asi= 0.0
while(loop):
gps.readUart()
if(gps.messages() > 0):
while(gps.messages() > 0):
message_to_xcsoar_udp = gps.getNMEA() # get one awaiting NMEA sentences
ap.udpSend(message_to_xcsoar_udp) # and send it
# try:
# print(message_to_xcsoar_udp.decode('UTF-8'))
# except Exception as e:
# print(e)
aud.do(bario.readVARIO())
a = sensors.readALTI()
v = sensors.readVARIO()
asi =sensors.readASI() ## make sure there is not data for ASI below just''
message_to_xcsoar_udp = lx.get('{:.2f}'.format(asi), '{:.2f}'.format(a), '{:.2f}'.format(v))
aud.do(v)
time.sleep(0.1)
## if button is low loop exits and preforms a shutdown
print("shutting down")
aud.doEndTune()
print("1")
gps.end()
print("2")
ap.end()
print("3")
aud.end()
print("4")
rp2.PIO(0).remove_program()
print("5")
timer.deinit()
print("6")
sensors.endCore1() # this is not returning ???
print("shutdown")
sys.exit()
WAP.py
import network
import socket
import machine
import time
class wap:
def __init__(self, ssid, password):
print("Starting WAP")
self.ssid = ssid
self.password = password
self.ap = network.WLAN(network.AP_IF)
self.ap.config(essid=ssid, password=password)
self.ap.active(True)
# print(self.ap.config("mac"))
# print(self.ap.config("essid"))
# print(self.ap.ifconfig())
conf = self.ap.ifconfig()
UDP_IP = str(conf[0])
print(UDP_IP)
UDP_IP_list = UDP_IP.split('.')[0:3] + ['255']
self.UDP_IP = '.'.join(UDP_IP_list)
# self.UDP_IP = '192.168.4.16'
print(self.UDP_IP)
self.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
def udpSend(self, msg):
XCSOAR_UDP_PORT = 4353
self.sock.sendto(msg, (self.UDP_IP, XCSOAR_UDP_PORT))
self.sock.sendto(msg, (self.UDP_IP, 2000))
def end(self):
self.ap.active(False)
def rex(self, p):
UDP_PORT = p
self.sock.settimeout(0.10)
try:
data, address = self.sock.recvfrom(1024)
print(address, data.decode())
except:
pass
# ap = wap("W-ap", "123456789")
# x =100
# while(x):
# # ap.udpSend(MESSAGE)
# ap.rex(4353)
# print('.')
# time.sleep(1.0)
# x -= 1
class station:
print("Starting joining wifi WAP")
self.ssid = ssid
self.wlan = network.WLAN(network.STA_IF)
# self.wlan.config(essid=self.ssid, password=self.password)
self.wlan.active(True)
res =self.wlan.scan()
for each in res:
print(each)
# self.wlan.connect(self.ssid, self.password)
# conf = self.wlan.ifconfig()
# UDP_IP = str(conf[0])
# UDP_IP_list = UDP_IP.split('.')[0:3] + ['255']
# self.UDP_IP = '.'.join(UDP_IP_list)
# print(self.UDP_IP)
# self.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
def end(self):
self.wlan.active(False)
# w = station("Galaxy A71B468", "jcye9075")
# x = 10
# while(x):
# print(x)
# time.sleep(1.0)
# x-=1
# w.end()
# print("end")
audio.py
import machine
from rp2 import PIO, StateMachine, asm_pio
#from machine import Timer
import time
import utime
# to fix ENOMEM error
#rp2.PIO(0).remove_program()
# PIO code from https://hackspace.raspberrypi.com/articles/raspberry-pi-picos-pio-for-mere-mortals-part-3-sound
## importing this will load and prep the PIO code.
## The audio class below will activate it as required for the tone to sound
@asm_pio(sideset_init=PIO.OUT_LOW)
def square_prog():
label("restart")
pull(noblock) .side(0)
mov(x, osr)
mov(y, isr)
#start loop
#here, the pin is low, and it will count down y
#until y=x, then put the pin high and jump to the next secion
label("uploop")
jmp(x_not_y, "skip_up")
nop() .side(1)
jmp("down")
label("skip_up")
jmp(y_dec, "uploop")
#mirror the above loop, but with the pin high to form the second
#half of the square wave
label("down")
mov(y, isr)
label("down_loop")
jmp(x_not_y, "skip_down")
nop() .side(0)
jmp("restart")
label("skip_down")
jmp(y_dec, "down_loop")
max_count = 5000
freq = 1000000
#square_sm = StateMachine(0, square_prog, freq=freq, sideset_base=Pin(0))
square_sm = StateMachine(0, square_prog, freq=freq, sideset_base=Pin(28))
#pre-load the isr with the value of max_count
square_sm.put(max_count)
square_sm.exec("pull()")
square_sm.exec("mov(isr, osr)")
class audio:
def __init__(self):
''' usinf a POI state machine for the signal generator, calculate the freq, on time and off time of the audio vario '''
print("Starting Audio")
self.freq = 4000
self.freqLast = 4000
self.pause = 10
self.beep = 200
self.beepOntime = time.ticks_ms() + self.pause
self.beepOfftime = time.ticks_ms() + self.beep
self.vario = 0.0
self.tune = True
self.beat = 0
square_sm.put(4000)
## setup and start the time that will call the do function
# self.timer = Timer(-1)
# self.timer.init(period=100, mode=Timer.PERIODIC, callback=self.do)
## once setup simply update the vario variable. Usage show below
def setV(self, v):
self.tune = True
# print(v)
# print(v, self.freq, self.beep, self.pause)
def setTune(self):
self.tune = True
self.beat = 0
# def do(self, tm):
def do(self, v):
# self.tune = True
self.vario = v
ticks = time.ticks_ms()
baseF = 4000
liftPosThres = 0.2
sinkNegThres = -1.1
if(self.vario >= liftPosThres):
self.freq = int(baseF + int(self.vario * 100.0))
self.pause= 75
self.beep = 1000 - int(self.vario * 100)
elif(self.vario > sinkNegThres):
self.beep = 0
self.freq = 500
elif(self.vario < sinkNegThres):
self.freq = int(baseF/2 + int(self.vario * 100.0)) # v is negative
self.pause = 50
self.beep = 3000
else:
print("error v out of range")
if(self.beep <= 0): self.beep = 0
if(self.freq != self.freqLast): # not pulling from the buffer
square_sm.put(self.freq) # when we put there
if(square_sm.tx_fifo() > 2): # requires a
square_sm.exec("pull()") # pull to stop it blocking up
self.freqLast = self.freq
if(self.beep > 0): # should beep be working
if(square_sm.active()): # is it on now
if(utime.ticks_diff(ticks, self.beepOfftime) >= 0):
square_sm.active(0) # turn off and calculate next on time
self.beepOntime = utime.ticks_add(ticks, self.pause)
else:
if(utime.ticks_diff(ticks, self.beepOntime) >= 0):
square_sm.active(1) # turn onand calculate next off time
self.beepOfftime = utime.ticks_add(ticks, self.beep)
else:
square_sm.active(0)
def doTune(self):
if(self.beat < 5):
square_sm.put(4000)
square_sm.active(1)
self.beat += 1
elif(self.beat < 10):
square_sm.put(3000)
self.beat += 1
elif(self.beat < 20):
square_sm.put(4900)
self.beat += 1
elif(self.beat < 40):
square_sm.put(4000)
self.beat += 1
elif(self.beat < 50):
square_sm.active(0)
self.beat = 0
self.tune = False
def doStartBeep(self):
square_sm.put(3000)
square_sm.active(1)
time.sleep(0.2)
square_sm.active(0)
time.sleep(0.1)
def doStartTune(self):
square_sm.put(3500)
square_sm.active(1)
time.sleep(0.05)
square_sm.active(0)
time.sleep(0.1)
square_sm.active(1)
time.sleep(0.1)
square_sm.active(0)
time.sleep(0.1)
square_sm.put(4500)
square_sm.active(1)
time.sleep(0.2)
square_sm.active(0)
def doEndTune(self):
square_sm.put(4500)
square_sm.active(1)
time.sleep(0.05)
square_sm.active(0)
time.sleep(0.1)
square_sm.active(1)
time.sleep(0.1)
square_sm.active(0)
time.sleep(0.1)
square_sm.put(3500)
square_sm.active(1)
time.sleep(0.2)
square_sm.active(0)
def end(self):
# self.timer.deinit()
square_sm.active(0)
## usage example
#import random
# aud = audio()
# var = 0.0
# x=5
# while(x):
# aud.doStartTune()
# time.sleep(1.0)
# # var += 0.00 + float(random.randrange(-10,10)/100.0)
# # aud.setV(0.2)
# # time.sleep(0.1)
# # aud.setV(0.0)
# # time.sleep(0.1)
# # aud.setV(-2.0)
# # time.sleep(0.1)
# x-=1
# print(x)
# # to stop the noise!!! run this only
# square_sm.active(0)
# aud.end()
# rp2.PIO(0).remove_program()
sensors.py
#import machine
from machine import Pin, I2C
import _thread
import utime
import time
import math
## Starting a new thread on the PICO, should put it in Core1
## use a loop to get/process the ASI pressure sensor and the Altimeter/Vario sensor
global ASIfinal
ASIfinal = 0.0
global ALTIfinal
ALTIfinal = 0.0
global VARIOfinal
VARIOfinal = 0.0
global TIMEsample
TIMEsample = utime.ticks_ms()
global PRESSfinal
PRESSfinal = 0.0
global TEMPfinal
TEMPfinal = 0.0
global core_one_run
core_one_run = True
def readASI():
global ASIfinal
return ASIfinal
def readALTI():
global ALTIfinal
return ALTIfinal
def readVARIO():
global VARIOfinal
return VARIOfinal
def endCore1():
global core_one_run
print("c1")
core_one_run = False
print("c2")
time.sleep(0.5)
print("c3")
_thread.exit()
print("c4")
def sensors():
global ASIfinal
global ALTIfinal
global VARIOfinal
global TIMEsample
global core_one_run
# hardware setup hardcoded for now
i2cAsix = 0
i2cAsiAddr = 0x21
i2cAVx = 0
i2cAVAddr = 0x77
# setup ASI pressure readings
IAS = 0.0
i2cAsi = I2C(i2cAsix, scl=Pin(21), sda=Pin(20), freq=100000)
diffP = 0.0
temp = 0.0
i2cAsi.writeto(i2cAsiAddr, bytearray([0x36, 0x03]), 2)
# setup Barometric pressure sensor for Alti and Vario
i2cAV = I2C(i2cAVx, scl=Pin(21), sda=Pin(20), freq=100000)
i2cAV.writeto(i2cAVAddr, bytearray([0x1E])) # reset_cmd()
utime.sleep_ms(200)
data = i2cAV.readfrom_mem(i2cAVAddr, 0xA2, 2)
C1 = data[0] * 256 + data[1]
data = i2cAV.readfrom_mem(i2cAVAddr, 0xA4, 2)
C2 = data[0] * 256 + data[1]
data = i2cAV.readfrom_mem(i2cAVAddr, 0xA6, 2)
C3 = data[0] * 256 + data[1]
data = i2cAV.readfrom_mem(i2cAVAddr, 0xA8, 2)
C4 = data[0] * 256 + data[1]
data = i2cAV.readfrom_mem(i2cAVAddr, 0xAA, 2)
C5 = data[0] * 256 + data[1]
data = i2cAV.readfrom_mem(i2cAVAddr, 0xAC, 2)
C6 = data[0] * 256 + data[1]
## setupthe kalman filter
ALTIfinal = 0.0 # x_abs
VARIOfinal = 0.0 # x_vel
t = utime.ticks_ms()
dt = 0.03 # sample interval
cz = 7000.0 # p_abs_abs
cv = 0.0 # p_abs_vel
cdv = 0.0 # p_vel_vel
vz = 0.1 # var_z_abs
# setup done now loop doing the read/conversions/processing
while(core_one_run):
# do ASI sensor read and process
def checkCRC(data, size, csum): # this used only for ASI chip
crc = 0xff
for i in range(0, size, 1):
crc ^= data[i]
crc &= 0xff
for bit in range(8, 0, -1):
if(crc & 0x80):
crc = (crc << 1) ^ 0x31
crc &= 0xff
else:
crc = crc << 1
crc &= 0xff
return (crc == csum)
data = i2cAsi.readfrom(i2cAsiAddr, 3)
p = data[0:2]
pcrc = data[2]
IAS = 0.0
press = 0
if checkCRC(data[0:2], 2, data[2]):
press = p[0] *256 + p[1]
if press & 0x8000: ## handle the signed int
press -= 0x10000
press /= 60.0
else:
print("err")
if(press > 0.0):
IAS = math.sqrt(press * 1.568135)
if IAS < 1.0:
ISA = 0.0
ASIfinal = IAS
# print(ASIfinal)
# do Bari sensor reading and process
i2cAV.writeto(i2cAVAddr, bytearray([0x48])) #pres_conversion()
utime.sleep_ms(10)
value = i2cAV.readfrom_mem(i2cAVAddr, 0x00, 3) # read_pressure()
D1 = value[0] * 65536 + value[1] * 256 + value[2]
i2cAV.writeto(i2cAVAddr, bytearray([0x58])) # temp_conversion()
utime.sleep_ms(10)
value = i2cAV.readfrom_mem(i2cAVAddr, 0x00, 3) # read_temp()
D2 = value[0] * 65536 + value[1] * 256 + value[2]
"""Conversion of the read data to get the final output"""
dT = D2 - (C5 * 256)
TEMP = 2000 + ((dT * C6) / 8388608)
OFF = C2 * 65536 + (C4 * dT) / 128
SENS = C1 * 32768 + (C3 * dT ) / 256
T2 = 0
OFF2 = 0
SENS2 = 0
if TEMP >= 2000 :
T2 = 0
OFF2 = 0
SENS2 = 0
elif TEMP < 2000 :
T2 = (dT * dT) / 2147483648
OFF2 = 5 * ((TEMP - 2000) * (TEMP - 2000)) / 2
SENS2 = 5 * ((TEMP - 2000) * (TEMP - 2000)) / 4
if TEMP < -1500 :
OFF2 = OFF2 + 7 * ((TEMP + 1500) * (TEMP + 1500))
SENS2 = SENS2 + 11 * ((TEMP + 1500) * (TEMP + 1500)) / 2
TEMP = TEMP - T2
OFF = OFF - OFF2
SENS = SENS - SENS2
PRESSfinal = ((((D1 * SENS) / 2097152) - OFF) / 32768.0) / 100.0
TEMPfinal = TEMP / 100.0
# print(PRESSfinal, TEMPfinal)
QNH = 1013.25
alti = 44330.0 * (1 - (PRESSfinal / QNH)** 0.190295)
# print(alti)
# avkalman(alti) now inline
tn = utime.ticks_ms() # Manage the time between samples dt
dt = float(utime.ticks_diff(tn, TIMEsample))/1000.0
TIMEsample = tn
# print("dt ", dt)
var_accel = 1.0 # a constant, never get changed?
ALTIfinal += VARIOfinal * dt ## expected Alti
# update state covariance, calculated from last samples variables
cz += (2.0 * dt * cv) + (dt**2 * cdv) + (var_accel * dt**4) /4.0 # static local
cv += dt * cdv + (var_accel * dt**3)/2.0 # static local
cdv += var_accel * dt**2 # static local
# update
y = alti - ALTIfinal ## error, difference between actual and expected Alti
s_inv = 1.0 / (cz + vz) # local
k_abs = cz * s_inv # Kalman gain od alti # local
k_vel = cv * s_inv # Kalman gain od vario # local
# update state estimate ## no need to check lock as this is the only locking
ALTIfinal += k_abs * y ## Alti and
VARIOfinal += k_vel * y ## vario
cdv -= cv * k_vel ## as above these are static value to be used to test adjust next sample
cv -= cv * k_abs
cz -= cz * k_abs
# print(ALTIfinal, VARIOfinal)
time.sleep(0.1)
print("Endcore1")
def startSensors():
print("Starting Sensors _thread")
try:
_thread.start_new_thread(sensors, ())
print("err ", e)
## usage example
#startSensors()
# x=50
# while(x):
# time.sleep(0.05)
# print(readASI(), readALTI(), readVARIO())
# x-=1
# endCore1()
# print("end")
gpsuart.py
from machine import UART
import time
import utime
class gpsUart:
def __init__(self):
print("Starting gpsUart")
# self.prefixes = ['$GNGGA','$GPGSA','$GLGSA','$GNRMC','$GNVTG']
self.msgs = []
self.rxData = bytes()
#### Start Uart for the GPS ####
self.uart = UART(0, baudrate=9600, tx=Pin(16), rx=Pin(17)) ## changed from original for veroboard unit (PL)
# self.timer.init(period=50, mode=Timer.PERIODIC, callback=self.readUart)
def messages(self):
return len(self.msgs)
def getNMEA(self):
if(len(self.msgs) > 0):
return self.msgs.pop(0)
def readUart(self):
# rxData = bytes()
while self.uart.any() > 0:
b = self.uart.read(1)
self.rxData += b
if (b == '\n'.encode('UTF8')):
self.msgs.append(self.rxData)
while(len(self.msgs) > 10):
self.msgs.pop(0)
print("gpsUart msg buffer > 10, popping")
# utime.sleep_ms(1)
def dummy(self, x): ## call with x = 0 to 4
def gpstimeStr():
return (str(time.gmtime()[3]) + str(time.gmtime()[4]) + str(time.gmtime()[5]))
if x == 0:
# generate GNGGA sentence
ggaSuffix = ",3731.575481,S,14525.516744,E,1,4,2.07,374.105,M,-2.272,M,,"
gga = "GNGGA," + gpstimeStr() + ggaSuffix
crcgga = self.crcCalc(gga)
ggaStr = "$" + gga + "*" + '{0:x}'.format(crcgga)+ "\r\n"
return ggaStr
# copy GNPSA and GLSA sentences
elif x == 1:
pgsa = "$GPGSA,A,3,25,05,15,29,,,,,,,,,2.29,2.07,0.98*02" + "\r\n"
return pgsa
elif x == 2:
lgsa = "$GLGSA,A,3,,,,,,,,,,,,,2.29,2.07,0.98*13" + "\r\n"
return lgsa
elif x == 3:
# generate GNRMC sentence
rmcSuffix = ",A,3731.575481,S,14525.516744,E,1.21,209.33,300822,,,A"
rmc = "GNRMC," + gpstimeStr() + rmcSuffix
crcrmc = self.crcCalc(rmc)
rmcStr = "$" +rmc + "*" + '{0:x}'.format(crcrmc)+ "\r\n"
return rmcStr
elif x == 4:
vtg = "$GNVTG,209.33,T,,M,1.21,N,2.23,K,A*29" + "\r\n"
return vtg
else:
print("Error in dummy gps number")
return None
def crcCalc(self, sentence): # sentence in bytearray form
byCRC = 0
if type(sentence) != bytes:
sentence = bytearray(sentence.encode('UTF8'))
for each in sentence:
byCRC ^= each
return byCRC
def end(self):
time.sleep(0.1)
## Usage example
# gps = gpsUart()
# x = 50
# while(x):
# gps.readUart()
# res = gps.getNMEA()
# if res != None:
# try:
# print(res.decode('UTF8'))
# except:
# pass
# x-=1
# time.sleep(0.1)
# gps.end()
# x = 0
# for each in gps.msgs:
# print(x)
# print(each.decode('UTF8'))
# x+=1
lxnav.py
class LXNAV:
def __init__(self):
''' create the LXNAV LXZP0 sentence for XCSoar '''
# eg usage string to bytearray sbytes = bytes(string, 'UTF8')
# crc = crcCalc(sbytes)
byCRC = 0
byCRC ^= each
return byCRC
def get(self, asi, alti, vario):
# use a list of data to fill in the sentence, end with CRC
# output format $LXWP0,N,'tas km/h','altutude m', v0 m/s, v1 m/s, v2 m/s, v3 m/s, v4 m/s, v5 m/s, heading, wDir, wSpeed]
# eg $LXWP0,Y,119.4,1717.6,0.02,0.02,0.02,0.02,0.02,0.02,,000,107.2*5b
opstr = "LXWP0,N," + asi + ',' + alti + ',' + vario + ',,,,,,,,' ## initial opstr has to $ nor crc
sb = bytes(opstr, 'UTF8') ## make it a bytearray for the CRC
crc = self.crcCalc(sb)
## assemble and return
return bytearray(('$' + opstr + '*' + '{0:x}'.format(crc)+ "\r\n").encode('UTF8'))
Photos.
This is the latest desktop development arrangement. The code above was tested on this a few minutes ago.
This is how it started;
This is the Epaper version, lots to do yet…
Behind the display.
Having an ASI pitot on my harness or wrist is not going to be useful. So as the Kobo can still be wired up wth a serial port or USB-Serial adapter, I plan to mount the Pitot and interface on the back of the Kobo, facing the airflow. This is using a Seed Studios XIAO-RP2040. But lots of other options. I did try using a second Pico-w and connect to the first WAP to send the ASI data onto the Kobo via the same LXNAV sentence but I could not get 2 Clients to connect to the Pioc-W??
Have fun!
PeteL.
