I’ve just shared a new project: "Environment Monitor - V2"
This project started due to the smoke haze that enveloped our area during the 2019 and 2020 bushfires. I wanted something to check the air quality of my home and maybe find areas where it needed better sealing. In addition, the BMP280 sensor was on special, so it was built into the project as well. Given how easy it has become to use a Pi Zero, I’ve developed this as a quick and easy tool to be able to determine whether there’s any haze or contaminants which are present in the area this is located in remotely, which can then be forwarded anywhere in the world.
Hi Jim,
Good to see your project up! Awesome UI using Flask. The air quality sensor is quite interesting.
Hey James,
Thanks for sharing your project! An array of sensors similar to these strategically deployed with some LiPos and LoRa or similar technology such as your Version One of the project could be very useful for plenty of air quality services such as dust from industrial applications, or bushfires as you’ve noted.
Hi Jim,
Siiiick project, I wonder if it would be possible to rejig a couple of bits so it works with Cores new Piico sensors? and get the price down a bit (the Enviro+ board looks awesome but costs a bit).
@Bryce
LoRa would be perfect for this, getting the data into discrete packets is sometimes and issue but Jim’s method of doing a 5 min average is perfect!! I’m still doing some testing on one of my projects to monitor packet reliability for peer-peer comms as LoRaWAN rolls over to V3 (usually solved by having overlapping gateways).
I bought a couple of Raspberry Pi Pico’s and some of the Piico Dev sensors, yet to try them out.
The Enviro is an expensive board for what it does, I think most of the expense is in the Display, OLED’s are not cheap. Also the OLED is too small to be really effective and in the end is not really needed. The board being mounted on the Pi Zero, close to the processor, makes the on board temp and humidity sensors useless. Even with a Fan the sensor is influenced by the Pi too much.
The Air Quality sensor is also expensive but works really well.
I might have a look at the Piico sensors, using the current system with out the Enviro board.
Will post what I find, here.
Looking at what the Pimoroni Enviro does and comparing to Piico boards and others.
Pimoroni Enviro
BME280 temperature, pressure, humidity sensor
LTR-559 light and proximity sensor
MICS6814 analog gas sensor
MEMS microphone
0.96" colour LCD (160x80)
PiicoDev boards
PiicoDev Atmospheric Sensor BME280SKU: CE07503 $11.40
PiicoDev OLED Display Module (128x64) SSD1306 SKU: CE07911 $11.95
PiicoDev Adapter for Raspberry Pi SKU: CE07690 $3.95
Other boards to get same sensor function as the Enviro
Pimoroni LTR-559 Light & Proximity Sensor Breakout SKU: CE05970 $17.50
Adafruit I2S MEMS Microphone Breakout – SPH0645LM4H SKU: ADA3421 $12.55
Fermion: MEMS Gas Sensor - MiCS-5524 (Breakout) SKU: SEN0440 $15.70
Total cost $73.05 compare to Enviro of $99.95 (noting black & white display compared to colour)
But using modules like the PiicoDev range allows much more flexibility. The above was an exercise to see how to make exactly the same. Probably I would use the PiicoDev Pressure Sensor MS5637 and PiicoDev Precision Temperature Sensor TMP117 due to more accuracy rather than the BME280 and sacrificing humidity sensing.
I think Gas sensing would be better left to something more accurate. The sensors only return a resistance level which you have to play with the get PPM. It would be very easy to misinterpret the readings in code. If it was a storage area or where detecting gas leakage was a priority then the sensors could be used but with adequately designed code.
I dont have all the PiicDev sensors I need, so order to be placed. When I have worked through them I will post changes to the Python & HTML scripts from my project.
Hey Jim,
Awesome, super quick comparison as well! I’m keen to see this one get remixed.
Excellent point about sensing gas, if it was part of a safety system there would be a whole ton of safety factors that also come into play. An interesting note about the sensor using a resistance!
Well parts on the way.
Tested the PiicoDev Ambient Light Sensor VEML6030, works fine, name changes to code only. Very Simple.
But I have to say going from a Pi 4B GUI to a Pi Zero GUI is painful.
I am starting from scratch, flashed ‘Bullseye’ onto a SD card and set it up on a Pi Zero.
Might look into running Thorny on PC and connect to Pi via SSH. Previous programming has been Nano and SSH, a bit of a pain, GUI is so much better.
Python Code so far.
Only PMS5003 and Light Sensor available, waiting on arrival of other items.
Runs ok and output is from the Thonny Console screen.
Lots of commented out code.
Will have to determine how to activate the LCD screen, the Enviro sensor had a proximity function, the PiicoDev does not. Plan to use the Touch Pad, but forgot to order it.
Output.
| 03 Dec 2021 18:58:35 |
| Temperature| Pressure | | Light Lux | |
| 0.00 | 0.00 | | 4.00 | |
| PM 0.3 | PM 0.5 | PM 1.0 | PM 2.5 | PM 10.0 |
| 669 | 202 | 17 | 0 | 0 |
Run time = 00:07:01
Python Code.
# Environment Sensor V3.0
# - Temperature, Pressure, Lux, Noise
# - Particalection 1.0 2.5 10 microns
# enviro3.py
# Display sensor readings on the LCD
# Adapted from Environment Sernsor V2.1
# 03 Nov 2021 Adapt for use with PiicoDev devices.
# Light and Particle only devices available.
#!/usr/bin/env python3
import os
import datetime
import math
#import sounddevice
import numpy
#import board
#import busio
import base64
import multiprocessing
import logging
import threading
import json
#import serial
#import RPi.GPIO as IO
from PiicoDev_VEML6030 import PiicoDev_VEML6030
from PiicoDev_MS5637 import PiicoDev_MS5637
from PiicoDev_TMP117 import PiicoDev_TMP117
from PiicoDev_Unified import sleep_ms
from PiicoDev_SSD1306 import *
from time import sleep, time, asctime, localtime, strftime, gmtime
from pms5003 import PMS5003, ReadTimeoutError as pmsReadTimeoutError
from math import ceil, floor
from subprocess import call
from importlib import import_module
from flask import Flask, render_template, url_for, request, Response
# Interface setup
lightVEML6030 = PiicoDev_VEML6030()
#pressureMS5637 = PiicoDev_MS5637()
#tempTMP117 = PiicoDev_TMP117()
pms5003 = PMS5003(device='/dev/ttyAMA0',baudrate=9600,pin_enable=22,pin_reset=27)
#uart = serial.Serial("/dev/ttyS0", baudrate=9600, timeout=0.25) # waits 1/4 second for port
#IO.setmode(IO.BCM) # Set pin numbering
#IO.setup(4,IO.OUT) # Fan controller on GPIO 4
#pwm = IO.PWM(4,1000) # PWM frequency
#pwm.start(100) # Duty cycle
# LCD Setup
#displaySSD1306 = create_PiicoDev_SSD1306()
# text(string, x, y, colour) colour = 1 (white), 0 (black)
# needs font-pet-me-128.dat in running directory
# string up to 16 characters, x,y upper left corner
#displaySSD1306.text("Hello, World!", 0,0, 1)
#displaySSD1306.text(myString, 0,15, 1)
#displaySSD1306.text(str(myNumber), 0,30, 1)
#displaySSD1306.text("{:.2f}".format(myNumber), 0,45, 1)
#displaySSD1306.show()
#PiicoDev_SSD1306.poweroff()
#PiicoDev_SSD1306.poweron()
#PiicoDev_SSD1306.setContrast(contrast) contrast = 0 to 255
#create_PiicoDev_SSD1306(bus=, freq=, sda=, scl=, addr=0x3C)
# bus = 1 = RPi. freq = ignored RPi, sda, scl = only Pi Pico, addr = 0x3C or 0x3D
# Variables
record = {} # sensor readings now
data = [] # current sensor readings for up to last 5 minutes
days = [] # holds all the saved data
samples = 300 # Each file record is 5 minutes, 60 x 5 = 300 seconds
samples_per_day = 24 * 3600 // samples # // rounds down and truncates
Time_Start = datetime.datetime.now()
Seconds_Start = Time_Start.timestamp()
# Set up web application
app = Flask(__name__)
app.config['TEMPLATES_AUTO_RELOAD'] = True
log = logging.getLogger("werkzeug")
log.disabled = True
run_flag = True
# Create a filename from year and day number, ie 365 days in year
def filename(t):
return strftime("data/%Y_%j", localtime(t))
# Display LCD Message - 3 lines of 15 characters, centered or not
def Display_MSG(L1,L2,L3,c):
x = 2 # leave 2 pixels for non centered message
# displaySSD1306.rect(0,0,127,63,1)
if c == True:
x = (16 - len(L1)) / 2
# displaySSD1306.text(L1,x,1,1)
if c == True:
x = (16 - len(L2)) / 2
# displaySSD1306.text(L2,x,21,1)
if c == True:
x = (16 - len(L3)) / 2
# displaySSD1306.text(L3,x,42,1)
# displaySSD1306.show()
return
# Display text and data
def Display_Data(L1T,L2T,L3T,L1D,L2D,L3D):
# displaySSD1306.text(L1T,2,1,1)
# displaySSD1306.text(L1D,64,1,1)
# displaySSD1306.text(L2T,2,21,1)
# displaySSD1306.text(L2D,64,21,1)
# displaySSD1306.text(L3T,2,42,1)
# displaySSD1306.text(L3D,64,42,1)
return
# LCD Display Screens
def Info():
Time_Now = datetime.datetime.now()
Display_MSG("Environment","Monitor",Time_Now.strftime("%d/%m/%y %H:%M"),True)
return
def LCD_Temp_Pressure():
Display_Data(" Temp."," "," Press.",
"{:8.02f}".format(record['temp']),
"{:8.02f}".format(record['humi'])," ")
return
def LCD_PM():
Display_Data(" PM 10.0"," PM 2.5"," PM 1.0",
"{:5.0f}".format(record['pm100']),
"{:5.0f}".format(record['pm25']),
"{:5.0f}".format(record['pm10']))
return
def LCD_Light():
Display_Data(" Lux"," "," ",
"{:8.02f}".format(record['lux'])," "," ")
return
# LCD Screen selector
def LCD_Screen_Selector(s):
switcher = {
0: Info,
1: LCD_Temp_Pressure,
2: LCD_PM,
3: LCD_Light
# PiicoDev_SSD1306.setContrast(255)
func = switcher.get(s, lambda: "Invalid Screen")
func()
return
# LCD Display
def LCD():
prox_trig = False
LCD_OFF = False
LCD_Screen = 0
Display_MSG("Environment","Monitor",Time_Start.strftime("%d/%m/%y %H:%M"),True)
LCD_Display_Timer = datetime.datetime.now().timestamp() + 30
while run_flag:
# Add something to trigger display ON, cap touch pad or simple switch
# replaces if ltr559.get_proximity() > 600:
# if ltr559.get_proximity() > 600:
# if prox_trig == False:
# if LCD_OFF == True:
# LCD_Screen = 0
# LCD_Screen_Selector(LCD_Screen)
# LCD_Display_Timer = datetime.datetime.now().timestamp() + 30
# LCD_OFF = False
# LCD_Screen += 1
# if LCD_Screen > 5:
# LCD_Screen = 0
# prox_trig = True
# else:
# prox_trig = False
if LCD_Display_Timer < datetime.datetime.now().timestamp(): # LCD turns off after 30 seconds
# PiicoDev_SSD1306.setContrast(0)
LCD_OFF = True
sleep(0.3)
# Converts Time String into integer
def record_time(r):
t = r['time'].split()[3].split(':')
return int(t[0]) * 60 + int(t[1])
# Adds Sensor reads to list for 5 minute period
def add_record(day, record):
if record_time(record) > 0: # If not the first record of the day
while len(day) == 0 or record_time(day[-1]) < record_time(record) - samples // 60: # Is there a gap
if len(day):
filler = dict(day[-1]) # Duplicate the last record to forward fill
t = record_time(filler) + samples // 60
else:
filler = dict(record) # Need to back fill
t = 0 # Only happens if the day is empty so most be the first entry
old_time = filler["time"] # Need to fix the time field
colon_pos = old_time.find(':')
filler["time"] = old_time[:colon_pos - 2] + ("%02d:%02d" % (t / 60, t % 60)) + old_time[colon_pos + 3:]
day.append(filler)
day.append(record)
# Averge Sensor readings for save to file, 5 minute period
def sum_data(data):
totals = {"time" : data[0]["time"]}
keys = list(data[0].keys())
keys.remove("time")
for key in keys:
totals[key] = 0
for d in data:
for key in keys:
totals[key] += d[key]
count = float(len(data))
for key in keys:
totals[key] = round(totals[key] / count, 1)
return totals
# Read Sensors, Version 3 pressure temperature lux particles
def read_data(time):
# print ("read_data")
# particles = []
# pressure = pressureMS5637.read_pressure()
# altitude_m = pressure.read_altitude()
# temperature = tempTMP117.readTempC() # Celsius
# tempF = tempSensor.readTempF() # Farenheit
# tempK = tempSensor.readTempK() # Kelvin
lux = lightVEML6030.read()
# Rec = sounddevice.rec(8000,16000,blocking=True,channels=1,dtype='float64')
# RecAbs = numpy.abs(Rec)
# RecMax = numpy.max(RecAbs)
# noise = 20 * math.log(RecMax/1) # convert level to dB
while True:
try:
particles = pms5003.read()
break
except RuntimeError as e:
print("Particle read failed:", e.__class__.__name__)
if not run_flag:
raise e
pms5003.reset()
sleep(30)
pm100 = particles.pm_per_1l_air(10.0)
pm50 = particles.pm_per_1l_air(5.0)
pm25 = particles.pm_per_1l_air(2.5)
pm10 = particles.pm_per_1l_air(1.0)
pm5 = particles.pm_per_1l_air(0.5)
pm3 = particles.pm_per_1l_air(0.3)
record = {
'time' : asctime(localtime(time)),
# 'temp' : round(temperature,1),
# 'pres' : round(pressure,1),
'temp' : 0,
'pres' : 0,
'lux' : round(lux),
# 'noise': round(noise,1),
'pm03' : pm3,
'pm05' : pm5,
'pm10' : pm10,
'pm25' : pm25,
'pm50' : pm50,
'pm100': pm100
return record
# Reads Sensors, place in list, runs as separate thead
def Sensors():
global record, data
sleep(2)
last_file = None
while run_flag:
t = int(floor(time()))
record = read_data(t)
data = data[-(samples - 1):] + [record] # Keep five minutes
if t % samples == samples - 1 and len(data) == samples: # At the end of a 5 minute period?
totals = sum_data(data)
fname = filename(t - (samples - 1))
with open(fname, "a+") as f:
f.write(json.dumps(totals) + '\n')
if not days or (last_file and last_file != fname):
days.append([])
last_file = fname
add_record(days[-1], totals) # Add to today, filling any gap from last reading
# if it had been stopped
sleep(max(t + 1 - time(), 0.1))
# Startup Message on terminal
def Start_MSG():
print (" ")
print (" Environment Monitor - V3")
print (" ")
print (" ")
print ("Start Time ",Time_Start.strftime("%d %b %Y %H:%M:%S"))
print (" ")
return
# Print Sensor Readings
# Displaying 0.3 & 0.5 to indicate PMS5003 is working.
def print_Sensors():
global Time_Start
dt = datetime.datetime.now()
t = int(dt.timestamp() - Seconds_Start) # get seconds since start
h = int(t / 3600) # calc hours minutes & seconds since start
m = int((t - (h * 3600)) / 60)
s = int(t - (h * 3600 + m *60))
print ("|--------------------------------------|")
print ("| ",dt.strftime("%d %b %Y %H:%M:%S")," |")
print ("|----------------------------------------------------------------|")
print ("| Temperature| Pressure | | Light Lux | |")
print ("| {:8.02f} | {:8.02f} | | {:8.02f} | |"
.format(record['temp'],record['pres'],record['lux'],))
print ("|------------|------------|--------------------------------------|")
print ("| | | | | |")
print ("| PM 0.3 | PM 0.5 | PM 1.0 | PM 2.5 | PM 10.0 |")
print ("| {:7.0f} | {:7.0f} | {:7.0f} | {:7.0f} | {:7.0f} |"
.format(record['pm03'],record['pm05'],record['pm10'],record['pm25'],record['pm100']))
print (" Run time = {:02d}:{:02d}:{:02d}".format(h,m,s))
print (" ")
return # return time for next display
# Terminal Display
def Terminal():
Start_MSG()
Print_Sensor_Timer = Seconds_Start + 60 # display every minute
while run_flag:
if Print_Sensor_Timer < datetime.datetime.now().timestamp():
print_Sensors()
Print_Sensor_Timer = datetime.datetime.now().timestamp() + 60 # set time for next display
sleep(1.0)
# Reduce large sample (year) to what can be displayed on web page
def compress_data(ndays, nsamples):
cdata = []
for day in days[-(ndays + 1):]:
for i in range(0, len(day), nsamples):
cdata.append(sum_data(day[i : i + nsamples]))
length = ndays * samples_per_day // nsamples
return json.dumps(cdata[-length:])
# 300 @ 1s = 5m
# 288 @ 5m = 24h
# 336 @ 30m = 1w
# 372 @ 2h = 31d
# 365 @ 1d = 1y
# Web page access
@app.route('/')
def index():
return render_template('index.html')
@app.route('/readings')
def readings():
arg = request.args["fan"]
pwm.ChangeDutyCycle(int(arg))
return render_template('readings.html', **record)
@app.route('/graph')
def graph():
arg = request.args["time"]
if arg == 'day':
last2 = []
for day in days[-2:]:
last2 += day
return json.dumps(last2[-samples_per_day:])
if arg == 'week':
return compress_data(7, 30 * 60 // samples)
if arg == 'month':
return compress_data(31, 120 * 60 // samples)
if arg == 'year':
return compress_data(365, samples_per_day)
return json.dumps(data)
# Read all data that has been saved into a list for display on the graph
def Get_Saved_Data():
global days
if not os.path.isdir('data'): # create folder if not present
os.makedirs('data')
files = sorted(os.listdir('data')) # get all the file names
for f in files:
day = []
with open('data/' + f, 'r') as file: # open a file
for line in file.readlines(): # read each line
record = json.loads(line)
days.append(day)
return
# Main Run Loop Read the day data into a list from all the saved files
# Start sensor reads in background
# Start Flask web server as separate process
if __name__ == '__main__':
Sensors_thread = threading.Thread(target = Sensors)
LCD_thread = threading.Thread(target = LCD)
Term_thread = threading.Thread(target = Terminal)
record = read_data(time()) # first reading is not correct data
Get_Saved_Data() # get all saved data from all files
Sensors_thread.start() # start sensor reads and saves
LCD_thread.start() # start LCD display
Term_thread.start() # start LCD display
app.run(host='0.0.0.0', port=5000, threaded=True, debug=False)
# execution waits here till web process stopped
print (" ")
print ("Waiting for background to quit")
run_flag = False # stops background thread from running
Sensors_thread.join() # waits for background threads to stop
LCD_thread.join()
Term_thread.join()
Hi James.
This AQ system of yours still operational? Looking at doing something very similar in the shed for woodworking dust.
Mark
Hi Mark
Why would you want to detect woodworking dust.
If woodworking machinery os operating I think it would be safe to assume THERE WILL BE dust and extraction system (s) should be running.
If you are referring to a “Mens Shed” you might find that for OHS reasons any dust extraction system MUST be running, either automatically or manual. Does not matter what you measure. The assumption is there WILL be dust.
Hey James,
That’s a really practical project. The 2019-2020 bushfire smoke was a big issue, so having a simple Pi zero setup to monitor air quality makes a lot sense. The BMP280is a nice addition for extra environmental data too.
Thanks for sharing!
I would say that such a device would still be pretty useful in tracking whether the ventilation system is sufficient. Certainly if the exhaust fan was failing to extract dust in sufficient quantities, this could be used as an warning system.
@Mark285907, the Air Quality Sensor James is using is pretty sensitive, but should still be fine for measuring the levels of dust from woodwork. Hopefully @James46717 can reach out and let you know how it’s going four years later.
The sensor device was expensive and I managed to get some small particles inside it, not good.
This project I no longer have, the enviro board I dont rate very high.
Since then I have setup a weather station on my roof and the air quality sensor is a PiicoDev Air Quality Sensor ENS160.
This device is more robust and cheaper, it gives good results of general air quality, unsure how it would perform for dust.
Thanks for replying Jim.
I’ve got my prototype working, just waiting on a box and some bit and pieces before I put it together.
SEN55 for the particles.
ENS160 for the AQ and VOCs.
LCD for values and an RGB strip of LEDs for warnings.
Mark
