I’m working on a project to measure for loads across spinal segments. Basically we’re sending a segment of spine up in a rocket and want to measure the forces/stress/strain across different elements of the spine.
I’m not the most mechanically minded but I’m not even sure where to start with this one. There isn’t exactly a hard reference point to measure the strain against. If you wanted to mount a stain gauge to the spine segment you could measure it, but it may influence the behaviour as it compresses the strain gauge.
If you are expecting a lot of compression and movement you could try and capture the compression movement visually with a camera and compare it later to the amount of force applied needed to replicate that compression.
You might be able to tinker with some Velostat to get the compression values for the orange portion of your build! You might have to do some calibration to get accurate results.
I very much like Trent’s idea using a camera to measure the deflection of the vertical parts.
