Hey Champions, i have a pi5 that i wish to use as a nas for some connected hard drives. i made a terrible mistake within the OMV interface and lost basically everything useful. i followed the instructions to remove OMV entirely and reinstall but then wasnt able to recreate the user or even log in at all. then i weirdly lost eth connection from the pi. I flashed the os again, even did a full format of the sd card and reinstalled pi lite but now i cant even ssh back into the pi to set it all up again. no matter what i try i keep getting “sorry, try again.” error.
I have the correct ip, no go.
i used the hostname i created in setup (with .local) no go.
legend thank you. so i have managed to get it all back together. i had modem issues and that took a reset, i have the pi ip static and have finally managed to ssh in but only as root. so now i believe i need to set up a new user and delete the root user correct?
Ooh, I would not go ahead and delete the root user. I’m not sure it’s possible and if you managed it you’d probably brick your system in creative ways I have never seen before.
Just stop using the root user and you should be golden. <3
if youre confident enough absolutely push boundaries. i have a few spare sd’s and could have a semi sandboxed toy. i really need to get this one set up for nas first tho
um i think the pi had erased my external hdd. i havent done anything that would suggest it was going to. there was some 6tb of data on them. whats happened?
all ive done is attach them to the pi and installed samba to share them
Even when plugged into my macbook they all have no files. disk utility says they are empty aside from the folders that used to contain the files and the exfat fs data. i ran them through diskdrill and it can see them but a lot are saying unrecoverable. could permissions still be the issue?
dont stress about response times. youve been more than helpful.
A lack of read permissions can sometimes prevent files from being seen by the operating system, although the fact that you are being told that they are unrecoverable via diskdrill makes me think that is unlikely.
ummm yet to be seen but its currently in another deep dive. theres one main folder that if i can get that back ill be happy. i haven’t checked its progress today.
